So,
What u saying? Can't be done cause c thinks its at the end of string 'cause
it's a null string, no, I mean a string of nulls. Ouch! I git confused.
rufus
Sent: Thursday, August 19, 2004 4:09 PM
To: VRF
Subject: [vrf] Re: Importing DLL's, passing by reference
> Could one not create a string of nulls using the Data|Allocate Array|Text.
Nope. Try it. When you try to copy something to that string it will always
overflow and the result will maybe be a GPF. Any Text var can contain any
unsigned char *except* 0. Any time you stuff a 0 in anywhere, that
terminates the string. So, a string full of nulls has a length of 0. If you
try to use that to copy a string into, it will overflow.
-SHAWN-
You are currently subscribed to vrf as: rwarren@amti.net To subscribe send a
blank email to "join-vrf@it.lists.it.agilent.com".
rufus
To: VRF
-SHAWN-
