> Question: How do I unload the objects like how M$ suggested?
> Anyone who can modify the code to do this would be much appreciated.
Unfortunately you normally can't get rid of all references. VEE hangs on to
them for debugging purposes. If you turn debugging off, you have a much
better chance of deleting all object references.
-SHAWN-
-SHAWN-
Hi vrf,
Could someone give the correct Excel Automation calls for:
1)Add Trendline...
2)Select Polynomial , Order 2
I've looked at the VB Macro code for this..
Too much modifying..
Thanks Chris
