Not sure, but I think Agilent has a plug&play driver in the zip file,
driver_vxipnp_875x_a_01_01.exe. So go to the Agilent site and do a search.
Let us know if it works.
rufus
Sent: Friday, November 05, 2004 8:52 AM
To: VRF
Subject: [vrf] P&P drivers, learn strings, ...
(VEE Pro 6.2, WinNT)
I am currently interfacing an 8753B, though other 8753x's may need to be
supported later. Right now, I'm trying to upload and store the Learn
String, using a Direct I/O transaction. The upload itself works, but I'm
not clear on how to get the result into a file.
In the VRF archive, I found a similar question; one answer simply said to
use readLongLrnString() from the XIplug&play instrument driver. I haven't
used any P&P drivers so far. www.agilent.com has drivers for the 8753D & E,
but not explicitly for the 8753B.
1. I'm inferring from this that I can't use the P&P driver?
2. If I can't, I can still read the Learn String with a Direct I/O
'read BinBlock'. How would I get this into a file?
TIA,
George
rufus
To: VRF
TIA,
George
E, but not explicitly for the 8753B.
TIA,
George
