Question (2) below is probably premature: I've found something in the
archive that appears to answer that. I would still be interested in an
answer to (1), and some general insight as to the pros and cons (?) of
using P&P drivers instead of Direct I/O.
George
(VEE Pro 6.2, WinNT)
I am currently interfacing an 8753B, though other 8753x's may need to be
supported later. Right now, I'm trying to upload and store the Learn
String, using a Direct I/O transaction. The upload itself works, but I'm
not clear on how to get the result into a file.
In the VRF archive, I found a similar question; one answer simply said to
use readLongLrnString() from the XIplug&play instrument driver. I haven't
used any P&P drivers so far. www.agilent.com has drivers for the 8753D &
E, but not explicitly for the 8753B.
1. I'm inferring from this that I can't use the P&P driver?
2. If I can't, I can still read the Learn String with a Direct I/O
'read BinBlock'. How would I get this into a file?
TIA,
George
George
TIA,
George
