I agree with you that they make the usage even easier, but I have the impression that MC is not going to make the Vee libraries for their USM products anymore. Please correct if it is not so...
Tapio
> -----Original Message-----
> From: ext Schlieker, Reiner [mailto:reiner.schlieker@siemens.com]
> Sent: 05 November, 2004 20:04
> To: VRF
> Subject: [vrf] RE: VEE Pro and NI VI's and Measurement Computing USB d
> evic es
> Geez, if it's so easy to access the .dll, I guess I shouldn't
> have bought
> the VEE libraries after all :o). The libraries do make it
> even easier,
> tho...
> Reiner
> From: Stan Bischof [mailto:rsb@soco.agilent.com]
> Sent: Friday, November 05, 2004 12:06 PM
> To: VRF
> Cc: vrf@agilent.com
> evic es
> "Drago, William @NARDAEAST" <William.Drago@L-3com.com> wrote:
> > Jim,
> > I have had excellent results with VEE and the USB
> > products from Measurement Computing as well.
> > And, if you happen to need it, their tech support is outstanding.
> > -Bill
> Guess I'll chime in also- getting the PMD devices from Measurement
> Computing working with VEE was nearly trivial. Way under an hour
> starting "cold" (install driver in a few minutes, plug in the PMD,
> configure, start talking). Longest part was reading the very
> well-written documentation of the function calls and then creating
> a def file for VEE- but even that was no more than a half hour.
> Stan
> Stan Bischof Agilent Technologies 707-577-3994
> stan_bischof@agilent.com
> You are currently subscribed to vrf as: reiner.schlieker@siemens.com
> You are currently subscribed to vrf as: tapio.ronkainen@nokia.com
Tapio
> To: VRF
> evic es
> have bought
> even easier,
> tho...
> Reiner
> To: VRF
> Cc: vrf@agilent.com
> evic es
> > Jim,
> > -Bill
> Stan
