Phill,
import the Microsoft Scripting Runtime (Ax Automation).
Create a FileSystemObject and you can do all kind of directory things.
best regards,
G. Nied
Georg Nied - Software-Development - Hansestr.7 - 51149 Cologne - Germany
Tel: +49 2203 9770915 - Fax: +49 2203 9770924 - eMail:info@gn-software.de
-------- Original Message --------
Subject: [vrf] Create directory (05-Nov-2004 11:28)
To: vrf@agilent.com
> Hi all,
> I am trying to create a directory on a network drive that is always mapped.
> I can make a directory on my local drive using CMD but it's not working on
> the network drive. Is there an active x component i can use to do this.
> Thanks in advance.
> Regards,
> Phill Griffin
> Nokia UK Ltd
> Ext. 7486
> Mobile: 07766 513344
> You are currently subscribed to vrf as: g.nied@gn-software.de
> If you need help with the mailing list send a message to "owner-vrf@it.
best regards,
G. Nied
To: vrf@agilent.com
> Hi all,
> Thanks in advance.
> Regards,
> Phill Griffin
> Nokia UK Ltd
> Ext. 7486
I can make a directory on my local drive using CMD but it's not working on the network drive. Is there an active x component i can use to do this.
Thanks in advance.
Phill Griffin
Nokia UK Ltd
Ext. 7486
