Chaps,
A while a go the xq-comregisterex.zip was posted on the reflector to
register activex's. This was working fine until I installed the new service
pack for xp, now I get this error whenever I try to un register activex's
LoadLibrary("blah blah")
failed-The specified module could not be found. (regSvr32).
Has anyone else come across this problem and if so how did you overcome
this,
Many thanks in advance
Dean Moss Bsc(Hons)
Test Development Engineer
SSD Drives
dean.moss@ssddrives.com
Tel: 01903 737444
Fax: 01903 737121
this,
Dean Moss Bsc(Hons)
SSD Drives
Tel: 01903 737444
Fax: 01903 737121
I am calling a function in VeePro using Visual Basic. I am using
MScomm as a active x file in VEEPro but when I run my function from VB, the
MScomm does not initialise (the box is there but nothing in it). The
function works fine if I run it in VeePro. Do I need to declare MScomm
somewhere else??
Thanks in advance
Dean
Dean Moss
Eurotherm Drives
+44 (0) 1903737444
dean.moss@eurothermdrives.com
