vrf Pass variable by reference
Question asked by VRFuser on Dec 13, 2004
Hi All,
I need to use and dll, which allow me to write and read values to and
from an application using shared memory.
I have been able to write the values, becuase the variables I pass dont
need to be changed. But when I try to read, I have to pass a variable
that has to be "filled", and I haven't been able to do that.
The documentations says that for Delphi the header should be this:
(no is the memory index, valor is the value to be written or read)
procedure write_reg (no,valor:integer):
stdcall; external regist.dll;
procedure read_reg (no:integer; var valor: integer);
procedure write_reg_ana(no:integer;valor:single):
procedure read_reg_ana(no:integer;var valor:single):
procedure write_reg_str(no:integer;valor:pchar):
procedure read_reg_str(no:integer;var valor:pchar):
My problem is with read_reg, read_reg_ana and also with both string
functions.
I have been using:
long __stdcall write_reg(long no, long valor); //(integers)
long __stdcall write_reg_ana(long no, float valor);//(floating point,
32 bits, have not been able to use float64)
long __stdcall write_reg_str(long no, char* valor); //(strings)
long __stdcall read_reg(long no, long  *valor);
long __stdcall read_reg_ana(long no, float *valor);
long __stdcall read_reg_str(long no, char* valor);
Thankz in advance,
Nelson
