vrf Excel from Vee
Question asked by VRFuser on Nov 15, 2004
David,
This will work.  I did this before.  There are 2 things you need to do.
1.  Uncheck the debug feature in VEE setting or configuration.
2.  Then, you need to delete all Excel variables... like worksheet, sheet
and Excel application.  I do not know the exact one. But, I think the Excel
application variable must be delete at the end of your test or subroutine.
If you do this right, then the Excel.exe in the task will get delete.
Chao,
Han
From: Dave.Watling@Zarlink.Com [mailto:Dave.Watling@Zarlink.Com]
Sent: Monday, November 15, 2004 12:56 AM
To: VRF
Subject: [vrf] RE: Excel from Vee
Yes, it does look as if the Excel.exe task remains running invisibly.  This
shows me something about why it happens.  However, I don't know how to fix
it from Vee.  It's not causing me a problem right now.
Thankyou
David Watling
                      "Tran, Han"
                      <tranh@tycoelectr        To:       VRF
<vrf@agilent.com>
                      onics.com>               cc:
from Vee
                      12-Nov-2004 11:02
                      PM
                      Please respond to
                      "Tran, Han"
David,
Did you tried to delete the Excel in the Task Manager?
Then, Open the Excel Spreadsheet.
Han
Sent: Friday, November 12, 2004 3:35 AM
To: VRF
Subject: [vrf] Excel from Vee
I am creating an Excel object using 'GetObject', and everything works fine
- I can run VBA routines, read & write to cells etc.  However, after I
finish & exit from Vee, I can open the same Excel spreadsheet in Excel, and
when I look in the VBA editor, there are two copies of the spreadsheet
open.  If I run the 'GetObject' several times in Vee (and then exit), I get
a corresponding number of copies in Excel.  What on earth is going on here?
Why are the objects not being deleted after I exit from Vee?  I have tried
obj.close(0), and deleting the obj variable - it makes no difference.
Regards
David Watling
You are currently subscribed to vrf as: tranh@tycoelectronics.com
You are currently subscribed to vrf as: Dave.Watling@Zarlink.Com
