vrf Object Resizing Limitations
Question asked by VRFuser on Oct 17, 2004
Hi Chris -
thanks for the help.
Seemingly the objects size and grid properties only show when in panel
view...
I worked in full view (non-panel view) and the properties were not
there.
Off-Grid Move/Size:
Silly me.. I just realised I kept pressing the control key rather than
the shift
key *doh* So that shift key off-grid sizing works after all
Thanks again,
     Sascha.
> -----Original Message-----
> From: Chris Hall [mailto:chris.hall@test-engine.co.uk]
> Sent: 18 October 2004 11:50
> To: VRF
> Subject: [vrf] RE: Object Resizing Limitations
> Hi Sascha, VRF
> If you wan't to change the grid resolution for panel
> displays, the following
> extract from the help file should help.
> From the Main Window's object menu, select Properties.
> 2. Select the Panel tab.
> 3. Set the Grid Size. The smallest grid size is 1.
> 4. Click OK.
> When you change grid size, existing objects on the panel do not
> automatically align to the grid.  When you click on an object, its
> upper-left corner aligns to the nearest grid detent. When you
> click on the
> corner resize area, the object resizes to the nearest grid
> detent.  Any Move
> or Size aligns the object to the current grid size.
> Note
> Each panel has its own grid. To change the grid size on a
> UserObject or
> UserFunction grid, select Properties from its object menu and
> then follow
> the rest of the steps listed above.
> Copyright (c) 1991-2000 Agilent Technologies, Inc.
> Hope this does it
> Regards
> Chris
> From: SPANGENBERG,SASCHA (A-Scotland,ex1)
> [mailto:sspangenberg@agilent.com]
> Sent: 18 October 2004 10:58
> To: VRF
> Subject: [vrf] Object Resizing Limitations
> Hi All -
> sorry for this trivial question but frustration is growing and maybe
> there
> is a way to do this..
> Is there a way to resize objects without having predefined
> resize steps?
> E.g. when I try to resize a check box by clicking on one of
> the corners
> and dragging it, the item "snaps" to certain sizes.
> I cannot give it the exact size that I want it to be.. very
> frustrating
> indeed!
> For some objects I can specify the size dirctly through the properties
> but seemingly
> I cant do this with all objects, e.g. check box does not have a size
> entry ..  why not?
> It would be nice to disable the snap feature and allow resizing by
> mouse..
> maybe pressing shift while resizing by mouse could disable the snap
> feature
> temporarily?
> Anyway if someone knows a way to set the size of a check box manually
> please let me know..
> Many thanks,
>     Sascha
> You are currently subscribed to vrf as: chris.hall@test-engine.co.uk
> To send messages to this mailing list,  email "vrf@agilent.com".
> You are currently subscribed to vrf as: sspangenberg@agilent.com
