Dave,
I tried it and it works. I'm looking to see if I can builds or find
hardware that display LED...
Han
From: Dave.Watling@Zarlink.Com [mailto:Dave.Watling@Zarlink.Com]
Sent: Friday, December 03, 2004 1:02 AM
To: VRF
Subject: [vrf] Re: VEE to control parallel port
The example I gave was written in Vee 6.01. I believe it should work for
you, shouldn't it?
Dave
Thomas.Mitchell@A
utoliv.com To:
cc:
02-Dec-2004 06:30 Subject: Re: [vrf] Re: VEE
PM
I saw the postings on using the printer port. Do you have any examples in
VEE PRO 6.0?
Thanks
Tom
| | Dave.Watling@Zarl|
| | ink.Com |
| | 11/30/2004 03:48 |
| | AM |
| | Please respond to|
| | Dave.Watling |
| To: VRF <vrf@agilent.com>
| cc:
People use various methods, but I use Inpout, as it automatically installs
a driver required for NT versions of Windows.
Here is the link:
http://www.logix4u.net/inpout32.htm
Note: If you are running an 'NT' version of Windows (WinNT, Win2k, WinXP),
you will need to run it for the first time with administrator privaleges,
so it can install the driver for you.
If you need some code examples, just ask.
Regards
David Watling
Kang
ChiaChiek-CCK053 To: VRF
<vrf@agilent.com>
<chiachiek.kang@mo cc:
torola.com> Subject: [vrf] VEE to
30-Nov-2004 07:11
AM
Please respond to
Kang
ChiaChiek-CCK053
Hi guys,
I have limited power supply and would like to use parallel port instead to
control my digital lines.
Do you know of any built-in function/ any written program that could be
shared in order for me to control the parallel port using Agilent VEE?
Thanks!
CC Kang
(Tel#: 04-8503833)
You are currently subscribed to vrf as: Thomas.Mitchell@Autoliv.com
You are currently subscribed to vrf as: tranh@tycoelectronics.com
Han
To: VRF
you, shouldn't it?
Dave
Thomas.Mitchell@A
utoliv.com To:
cc:
PM
VEE PRO 6.0?
Thanks
Tom
| | Dave.Watling@Zarl|
| | ink.Com |
| | 11/30/2004 03:48 |
| | AM |
| | Please respond to|
| | Dave.Watling |
| cc:
Here is the link:
Regards
David Watling
Kang
<vrf@agilent.com>
30-Nov-2004 07:11
AM
Please respond to
Kang
ChiaChiek-CCK053
Hi guys,
Thanks!
CC Kang
(Tel#: 04-8503833)
Gotta go, bye.
-SHAWN-
you, shouldn't it?
Dave
Thomas.Mitchell@A
utoliv.com To: Dave.Watling@Zarlink.Com
cc:
02-Dec-2004 06:30 Subject: Re: [vrf] Re: VEE to control parallel port
PM
VEE PRO 6.0?
Thanks
Tom
| | Dave.Watling@Zarl|
| | ink.Com |
| | 11/30/2004 03:48 |
| | AM |
| | Please respond to|
| | Dave.Watling |
| cc:
Here is the link:
Regards
David Watling
Kang
<vrf@agilent.com>
30-Nov-2004 07:11
AM
Please respond to
Kang
ChiaChiek-CCK053
Hi guys,
Thanks!
CC Kang
(Tel#: 04-8503833)
