programName() gives me the .vxe file name
Regards, Axel
Von: Mike Groves [mailto:mike@grovesnet.org]
Gesendet am: Dienstag, 9. November 2004 09:48
An: VRF
Betreff: [vrf] RE: Source File Name in Executable
Alex,
OK, I didn't read your post clearly enough. I see you want this done
"automatically". I'm not sure how to do this without directly editing
the .VEE program file.
Shawn, when running a .VXE file, doesn't ProgramName() give you the
.VXE file name and not the name of the original .VEE file it was made
from?
Cheers,
Mike Groves
Sent: Tuesday, November 09, 2004 12:38 AM
To: a.kieser@francotyp.com; VRF
Subject: RE: [vrf] Source File Name in Executable
Hi Axel,
In your Main Panel, select Properties and set the "Execution Window Title"
to
(in your case) "Test07", "Test 7.00", or whatever you would like displayed.
When you create and run your .VXE file, (or run the .VEE file with the -r
command-line option), that text will be displayed in the title bar of the
running program.
Cheers,
Mike Groves
From: a.kieser@francotyp.com [mailto:a.kieser@francotyp.com]
Sent: Tuesday, November 09, 2004 12:16 AM
To: VRF
Subject: [vrf] Source File Name in Executable
Hi there,
is there a convenient way to get automatically the file name of the file the
runtime version is created from to be shown in the executable?
For a better understanding:
I create a file 'c: emp est07.vee', from that I create an executable
'test.vxe'. Now I want to see - e.g. in an alphanumeric display - a message:
'Source file: c: emp est07.vee'. When I create 'test.vxe' from
'c: emp est08.vee' it should be shown 'Source file: c: emp est08.vee'
without manual changes of the alphanumeric display of the source file .
Thanks for an answer in advance,
with best regards,
Axel
You are currently subscribed to vrf as: a.kieser@francotyp.com
Regards, Axel
An: VRF
Alex,
from?
Cheers,
Mike Groves
Hi Axel,
to
running program.
Cheers,
Mike Groves
To: VRF
Hi there,
with best regards,
Axel
o Use BaseName() to strip the path from the file name, as in
BaseName(ProgramName())
o A vxe is a "secured" (i.e., not human or development readable)
VEE program. There is no such thing as an "executable" VEE
program in the sense or x86 executable.
-SHAWN-
