Geez, if it's so easy to access the .dll, I guess I shouldn't have bought
the VEE libraries after all :o). The libraries do make it even easier,
tho...
Reiner
Sent: Friday, November 05, 2004 12:06 PM
To: VRF
Cc: vrf@agilent.com
Subject: [vrf] RE: VEE Pro and NI VI's and Measurement Computing USB d
evic es
"Drago, William @NARDAEAST" <William.Drago@L-3com.com> wrote:
> Jim,
> I have had excellent results with VEE and the USB
> products from Measurement Computing as well.
> And, if you happen to need it, their tech support is outstanding.
> -Bill
Guess I'll chime in also- getting the PMD devices from Measurement
Computing working with VEE was nearly trivial. Way under an hour
starting "cold" (install driver in a few minutes, plug in the PMD,
configure, start talking). Longest part was reading the very
well-written documentation of the function calls and then creating
a def file for VEE- but even that was no more than a half hour.
Stan
You are currently subscribed to vrf as: reiner.schlieker@siemens.com
tho...
Reiner
To: VRF
Cc: vrf@agilent.com
evic es
> Jim,
> -Bill
Stan
