Has any one had any experience using a controlling an NI-DAQ card with VEE
(version 6) using the NI-DAQmx driver?
I have controlled NI cards with DLL function calls through (non-mx) NI-DAQ
but I wanted to use one of the new M-series DAQ cards that only work with
the DAQmx drivers.
Otherwise, are there any other vendors cards with at least 24 DIO, 8 Analog
Inputs, 2 analog Outs, and a couple of timer/counter inputs with a base
clock accuracy of 50ppm, that operates with VEE fairly seemlessly.
Any suggestions would be most welcome.
Thanks
John.
the DAQmx drivers.
Thanks
John.
similar stuff to NI, and they have libraries for VEE.
Reiner
From: John Freriks [mailto:jfreriks@optusnet.com.au]
Sent: Friday, October 29, 2004 9:54 AM
To: VRF
Subject: [vrf] NI-DAQmx & VEE 6.0
the DAQmx drivers.
Thanks
John.
You are currently subscribed to vrf as: reiner.schlieker@siemens.com
