To: VEE users,
I'm using HP-UX 9 on a 745i platform with a VXI rack full of switch cards.
In converting to VEE 3.21 along with an associated upgrade of SICL D.01.00
I ran into the following:
1463,1460 and 1466 switch cards return the following after every OPEN or
CLOSE
command (in response to "SYST:ERR?"):
-240,"Hardware error"
The switches complete their functions very nicely however and the system
works fine if I just ignore the errors.
This does not happen with the prior versions of VEE and SICL.
The 240 error does not show up in any of my instrument manuals?
Any insights, suggestions, etc would be greatly appreciated.
Thanks in advance
Sincerely,
Rob Marquardt
System Test Engineering
Rockwell Automation/Allen-Bradley
414-382-3098
FAX 414-382-4455
RAMarquardt@mke5.ra.Rockwell.com
CLOSE
Thanks in advance
Sincerely,
Rob Marquardt
414-382-3098
FAX 414-382-4455
