VRF-Constant_Display
Question asked by VRFuser on Dec 8, 1996
send q VRF-Constant_Display ww vrf
to:   Johannes Mulder
date: Monday, 09 December 1996 1344 MST
> This mail I have sent before, without any reaction. I forgot to have
> the "VRF" indication in the subject. So I try again.
> Hi all,
> I have the next problem (under Win95, Vee3.2):
> A panel with a simple Constant object (array of coords).
> I use this to easily alter my array from a default value.
> I resized it to fit nicely (more narrow and more high), and
> positioned it at the far right of the screen.
> When I run my program and the constant is filled with the default,
> the object is automatically resized by VEE, so the scrollbar jumps
> off the screen.
> A userfunction with locking the panel does not help, securing my
> program neither.
> Any suggestions?? Thanks in advance!
This is a known problem with VEE that will be corrected in the next revision.
We know of no convenient workaround (though you might try a pop-up
userfunction and extract each value to alphanumeric objects).
> With kind regards,
>   Johannes Mulder
>   Philips Electron Optics            tel +31 40 2766947
>   Building AAE-room 21               fax +31 40 2766820
>   P.O.B. 218
>   5600 MD ACHT, the Netherlands
If you have more questions, let us know.
[<>] regards -- gvg
