Hello Cathy,
> I am currently using HP VEE version 3.0 under windows 3.11. I am using
> VEE with a number of test instruments to perform an automated test
> sequence.
> I am relatively new to using VEE, and am seeking to output the results in
> number format (from the HP VEE) to an Excel spreadsheet, for reporting
> purposes.
> Does anyone know the best way to do this, or have any pitfalls to avoid?
There's one pitfall I came accross, and it has to do with a bug in the
to/from DDE object. It concerns the Row/Column identifier the object
uses to let Excel know in which cell the data has to be written. If I
am right, it is not possible to directly write something like:
"R",row,"C",column in the item field, and using 'row' and 'column' as
data inputs. In any case, the solution is to make the string "RxCy"
outside the to/fromDDE object (with a To String obeject), add a data
input to it, for example named RxCy and using this variable in the item
field.
This is a known bug, and on the web site of HP you can find information you
need on this subject.
I hope this helps.
| Jaap Schuurmans Philips Semiconductors B.V. |
| E-mail: schuurmn@ehv.sc.philips.com PCALE |
| Seri: schuurmn@nlsce1 Building BE445 |
| Phone: +31-40-27 22058 P.O. BOX 218 |
| fax : +31-40-27 22764 5600 MD Eindhoven, The Netherlands |
> sequence.
> purposes.
field.
I hope this helps.
Email : cspencer@baea.com.au
Subject : Using DDE from HP VEE to Excel under windows
Hello everyone,
sequence.
purposes.
Cathy Spencer
British Aerospace Australia
Email: cspencer@baea.com.au
