to: Svein Stenbekk / VRf
date: Thursday, 18 July 1996 1021 MDT
Euro number formats? Been there ... done that ... from my VEE tutor:
[19.5] EURO NUMBER FORMATS WITH VEE
* In Europe, it is common to format numeric data in style that is reversed
from that used in the US -- with commas between the integer and fractional
part. Unfortunately there's no way to set this as a default in VEE. I
devised a function to do the job -- I put this in a formula box:
intPart(A) + "," + strFromLen(fracPart(A),2,strLen(fracPart(A)))
You could specify a numeric precision by replacing the last expression with a
fixed number or variable.
This can be converted to a UserFunction -- say, "c()" -- and used in
transaction objects ... and put in a user library.
