Corrupt file...
Question asked by VRFuser on Nov 4, 1996
I was working on a program I've been having problems with.  I finally solved
it.  Went to save it (I was using the same file name) and got a critical error
message.  Something about a "gizmo" (no, not kidding) not working right.  I
saved it under a different filename as I wanted to.  Now both of my files are
hosed.  I try to load it and it says it has problems loading a userobject
because it can't find an end of file at line XXX.  It is alot of work to
recover from my last backup if I could even find all the things I fixed.
Any help is appreciated.  Thanks.
Keith F. Jasinski, Jr.
Milwaukee Design Center
Department 1220-C
Outside   (414) 768-2427
GM-Net       8- 521-2427
FAX:               -2820
