Hi all!
Does anybody know how to give a f.e. 60 sec. long high signal on a parallel
Port pin or on a RS232 pin?
I want to drive a "Relais" or an "Optokopler".
Can somebody tell me what commands I can use.
Thanks for Your help.
I wish U a merry X-mas and a happy new Year.
Yours
Bjarne Roscher
from the Home of the famous norwegian "JULENISSE"!
Yours
Bjarne Roscher
to: VRf-Bjarne Roscher
date: Thursday, 19 December 1996 1010 MST
Please forgive me if I suggest that putting a short header in your message
(like the one above) and labeling the message with the tag "VRf" will help
reduce possible confusion among the ~200 people who are on the VEE Reflector.
Everyone uses different mailers and assuming that the mailer identifies the
message or its sender clearly is not valid.
> Hi all!
I presume you mean VEE ... under VEE 3.2X on Windows, you can use Direct I/O
to a serial port and do a WRITE IOCONTROL RTS (or DTR) ... then you can use a
delay to hang on for about 60 seconds.
> Yours
> Bjarne Roscher
stereo stereo stereo stereo
. t . t . t t .
.**j**. .**j**. .**j**. .**j**..
.***j*****O***. .***j*****O***. .***j*****O***. .***j*****O***.
merry xmas merry xmas merry xmas merry xmas
happy happy happy happy
new year new year new year new year
Sung to the tune of "Deck the Halls":
Deck us all with Boston Charley,
Walla Walla WA and Kalamazoo!
Nora's freezing on the trolley
Swaller-doller cauliflower alley-garoo!
Don't you know archaic barrel,
Lulabye, Lily-Boy, Louisville Lou!
Trolley-Molley don't love Harold,
Booley-booley Pensacooley Louisville Lou!
If you are not a primary English speaker, do not try to translate this since
it is not supposed to make sense (and will likely be just as baffling to an
American under the age of 40). In any case ...
joyeux noel
god yul
froehliche weihnachten und ein glueckliches neues jahr
prettige kerstdagen en enn gellukkig neiuwjaar / zalig kerstfeest
wesolych swiat i szczesliwego nowego roku
glaedelig jul & godt nytaar
feliz navidad y prospero ano nuevo
selamat hari natal dan selamat tahun baru
merry cristmas and a happy new year
