to: Remi Tuiktelaars
date: Thursday, 18 July 1996 1623 MDT
> Here is one of these annoying things we sometimes run into:
> 1. From the menus select 'DATA:CONSTANT:COMPLEX' and put on your model,
> making it al little larger than default for displaying larger number
> formats.
> 2. Try entering e.g. (1E-20,1E-20) or even (1E-40,1E-40) into the constant.
> 3. What do you see? Does it give resp. (10E-21, 10) or (100E-42, 10) on your
> system? Why 10?????
> We use vee 3.12 on HP-UX 9.05 on a 100MHz, 715 machine. However, vee 3.1
> on some PC with MS-windows 3.11 acts the same.
> Remi Tuijtelaars
> Philips Semiconductors, Dev. T&D, Building BY2.021,
> Gerstweg 2, NL-6534 AE Nijmegen, Netherlands.
> tel/fax: + 31 24 353 - 2812 / 3160.
> email: Remi.Tuijtelaars@nym.sc.philips.com
> (seri: nytuijte@nyhp02)
Remi / VRf:
Wha! This one just jumps right out at you! I duplicated it immediately ...
is a new one on us, I'll post it for resolution in the next release.
How commonly do you see this? As a workaround, try a Build Complex and two
Real constants (ugly, but workable).
When Ken in the lab gets back from vacation, he's gonna give me his slightly
cross-eyed open-mouthed "WOW" expression.
[<>] regards -- gvg
> formats.
> system? Why 10?????
> Remi Tuijtelaars
Remi / VRf:
[<>] regards -- gvg
