> Mhz machine... this was last Saturday. I moved the entire package from
> where it was installed (C:VEE31) to a new spot (C:WORK_RELATEDVEE31)
> and tried to fire it up on Sunday... it would only fired up what I think
> is a runtime-only version (you know no menu bar, etc.).
VEE like many packages has as part of it's config environment settings
in some of the system files. Not familiar with NT (yet!) so don't know
which one to point you to, but poke around in the usual places.
This would explain the "run-only" appearance (couldn't find the menu
definition file) and the "no id" (couldn't find that either).
hope this helps
Stan Bischof
stanb@sr.hp.com
hope this helps
Stan Bischof
stanb@sr.hp.com
customer that uses HP VEE 3.1 and therefore dug out my old copy and took
it home to install it and do some work over the weekend. I installed it
without any problems (yes, it did inform me that it belonged to me and
was I aware of it) and ran it without any problems on my Dell PPro 200
I did notice when I re-launched it that it said user:"unknown",
organization:"unknown" where as previously it had said my name and my
companies... what gives??? Did I miss a file somewhere??? I'd like to
fire it up this weekend without having to reinstall it again so any help
you can provide will be very appreciated.
