send q VRF-Multithreading vrf
to: VRf-Sergei Ermolin
date: Friday, 31 January 1997 1544 MST
> Thank you, Alex.
> Maybe, you can give me another hint:
> I am creating a real-time application. In short, I need to sample
> frequencies of 256 devices under test (DUTs) every 7 min +/- 15 sec and
> also communicate with them via RS-232 port using IEEE-488 GPIB
> controlled switching network. On top of that, there may be a
> considerable data reduction and operator data entry activity going on at
> the same time. The way I intend to implement that is by using multiple
> threads (one for frequency sampling, one for RS-232 communications, one
> for data analysis, one for operator interface refreshing, etc).
> The question is: how do I make frequency sampling thread to be the first
> priority in execution, so that I measure frequency in specified time
> intervals?
You can't really prioritize thread operations specifically; that would
imply determinism, which means that you want to do everything in one thread.
Please check the VEE tutorial I wrote on our netsite ... internal people
can get to it at:
HP SERVER:
http://hpislsup.lvld.hp.com/
-> PCTM Support -> VEE Tutor
The chapter on VEE control flow should give you some ideas on what to do.
> Also, is there any way to prevent RS-232 communication objects
> from locking up the system until they recieve appropirate response or
> time-out?
Unfortunately, I/O won't multitask ... if you do a timeout wait, nothing else
runs in that copy of VEE.
> Regards,
> Sergey Ermolin
If you have more questions, let us know.
[<>] regards -- gvg
> Thank you, Alex.
> intervals?
can get to it at:
HP SERVER:
> time-out?
> Regards,
> Sergey Ermolin
[<>] regards -- gvg
