> OK buttom to set the scales, but the repaet until that is running the
> virtual source steals all the time, so it dosnt matter how many times i
> press the OK buttom to set the scales, nothing happens !
> If I set a delay after the virtual source then it works.
> By for now.
> Henrik Grevelund
> mkpkor@inet.uni-c.dk
> P.S. I have some problems with sending mail to the forum, so if this mail
> isnt complete, then please send me a mote !
Sir:
Stan was right, you need to put a NEXT object in to ensure that the loop
completes properly. You also only need *one* Until-Break ... I have modified
the program accordingly and am returning it with this message.
If you have more questions, let us know.
[%%] regards -- gvg
(saveFormat "2.0")
(date "Sun 28/Jul/1996 13:20:32 MDT")
(veerev "3.2")
(platform "HP9000s700")
(SaveCF no)
(filterNAN 0)
(component 0 ROOTCONTEXT
(name "Untitled")
(implementation
(locked no)
(trigMode deg)
(nextID 22)
(component 0 TORECORD
(interface
(input 1
(name "Scale")
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(optional yes)
(input 4
(name "Max")
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(outputType scalar)
(component 1 YPLOT
(name "Strip Chart")
(interface
(input 1
(name "Trace1")
(lock constraints)
(input 2
(type control)
(name "Scales")
(tag "ScalesRecord")
(requires
(datatype Record)
(lock name constraints)
(optional yes)
(implementation
(tracePin 1)
(graphMode strip)
(component 2 VFUNCTIONGENERATOR
(interface
(output 1
(name "Func")
(implementation
(function Sine)
(frequency 1000)
(amplitude 1)
(dcOffset 0)
(phaseShift 0)
(numPoints 1024)
(interval 0.02)
(degRad Deg)
(errorOnAlias 1)
(component 3 LITERALCONSTANT
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "X")
(initValue Text
(data "")
(component 4 LITERALCONSTANT
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "M345linger")
(initValue Text
(data "")
(component 5 SLIDER
(name "Real Slider")
(interface
(output 1
(name "Real")
(implementation
(value Real
(values range 0 30000)
(data 14651.163)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(component 6 SLIDER
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 28430.233)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(component 7 JUNCTION
(name "JCT")
(interface
(input 1
(name "A")
(input 2
(name "B")
(output 1
(name "Data")
(component 8 LITERALCONSTANT
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "y")
(initValue Text
(data "")
(component 9 LITERALCONSTANT
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "M345linger")
(initValue Text
(data "")
(component 10 SLIDER
(interface
(output 1
(name "Real")
(implementation
(value Real
(values range -10 10)
(data -1.744)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(component 11 SLIDER
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 8.023)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(component 12 TORECORD
(interface
(input 1
(name "Scale")
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(optional yes)
(input 4
(name "Max")
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(outputType scalar)
(component 15 START25
(component 17 REPEATUNTILBREAK
(interface
(output 1
(name "Continuous")
(component 18 CONFIRM25
(interface
(output 1
(name "Go")
(implementation
(component enterButton yes)
(component escapeButton yes)
(component 19 NEXT
(component 20 CONFIRM25
(interface
(output 1
(name "Go")
(implementation
(component 21 EXITPROCESS
(implementation
(comp code 0)
(configuration
(connect D3:1 D0:1)
(connect D4:1 D0:2)
(connect D5:1 D0:3)
(connect D6:1 D0:4)
(connect D2:1 D1:1)
(connect D7:1 D1:2)
(connect D14:1 D2:0)
(connect D15:1 D5:0)
(connect D15:1 D6:0)
(connect D0:1 D7:1)
(connect D12:1 D7:2)
(connect D15:1 D10:0)
(connect D15:1 D11:0)
(connect D8:1 D12:1)
(connect D9:1 D12:2)
(connect D10:1 D12:3)
(connect D11:1 D12:4)
(connect D13:0 D14:0)
(connect D14:1 D15:0)
(connect D1:0 D16:0)
(connect D14:1 D17:0)
(connect D17:1 D18:0)
(viewFor -1
(active detail)
(detail
(geometry 0 55 1258 931)
(configuration
(viewFor 0
(active icon)
(icon
(geometry 553 455 95 51)
(iconImage "build.icn")
(detail
(geometry 576 279 98 82)
(terminals on)
(viewFor 1
(active detail)
(icon
(geometry 916 365 88 51)
(iconImage "display.icn")
(detail
(geometry 874 239 293 262)
(displayMode scrollGraph)
(graphType cartesian)
(gridType off)
(scale 0
(name "M345linger")
(domainName "M345linger")
(pen 9)
(show 1)
(range -1.744 8.023 4 linear)
(domain 0 13779.07 4 linear)
(trace 0 onScale 0
(name "Trace1")
(pen 4)
(lineType 1)
(pointType 0)
(stepSize 1)
(trackingEnabled 1)
(viewFor 2
(active icon)
(icon
(geometry 305 305 151 51)
(iconImage "virtual.icn")
(detail
(geometry 265 253 220 175)
(terminals on)
(viewFor 3
(active icon)
(icon
(geometry 462 403 36 15)
(detail
(geometry 193 276 214 29)
(viewFor 4
(active icon)
(icon
(geometry 463 432 34 17)
(detail
(geometry 193 336 214 29)
(viewFor 5
(active icon)
(icon
(geometry 329 463 83 15)
(detail
(geometry 201 449 119 222)
(layout vertical)
(fastmode off)
(viewFor 6
(active icon)
(icon
(geometry 329 533 83 15)
(detail
(geometry 371 609 119 222)
(layout vertical)
(fastmode off)
(viewFor 7
(active icon)
(icon
(geometry 796 428 28 25)
(detail
(terminals on)
(viewFor 8
(active icon)
(icon
(geometry 462 553 36 15)
(detail
(geometry 563 616 214 29)
(viewFor 9
(active icon)
(icon
(geometry 462 583 36 15)
(detail
(geometry 563 676 214 29)
(viewFor 10
(active icon)
(icon
(geometry 329 593 83 15)
(detail
(geometry 571 739 119 222)
(layout vertical)
(fastmode off)
(viewFor 11
(active icon)
(icon
(geometry 329 653 83 15)
(detail
(geometry 761 759 119 222)
(layout vertical)
(fastmode off)
(viewFor 12
(active icon)
(icon
(geometry 553 595 95 51)
(detail
(geometry 896 639 98 82)
(terminals on)
(viewFor 15
(active detail)
(icon
(detail
(geometry 136 110 49 20)
(title off)
(viewFor 17
(active icon)
(icon
(geometry 117 255 86 51)
(iconImage "loop.icn")
(detail
(terminals on)
(viewFor 18
(active detail)
(icon
(detail
(geometry 216 420 49 20)
(title off)
(viewFor 19
(active icon)
(icon
(geometry 1001 553 38 15)
(detail
(terminals on)
(viewFor 20
(active detail)
(icon
(detail
(geometry 256 160 49 20)
(title off)
(viewFor 21
(active icon)
(icon
(geometry 346 205 68 51)
(iconImage "stop.icn")
(detail
(geometry 344 215 72 31)
(connect D3:1 D0:1
(points 4 500 410 520 410 520 460 550 460)
(connect D4:1 D0:2
(points 4 499 440 510 440 510 470 550 470)
(connect D5:1 D0:3
(points 4 414 470 430 470 430 480 550 480)
(connect D6:1 D0:4
(points 4 414 540 430 540 430 490 550 490)
(connect D2:1 D1:1
(points 4 458 330 480 330 480 300 871 300)
(connect D7:1 D1:2
(points 2 826 440 871 440)
(connect D14:1 D2:0
(points 3 205 280 380 280 380 302)
(connect D15:1 D5:0
(points 3 267 430 370 430 370 460)
(connect D15:1 D6:0
(points 5 267 430 290 430 290 510 370 510 370 530)
(connect D0:1 D7:1
(points 4 650 480 670 480 670 430 793 430)
(connect D12:1 D7:2
(points 4 650 620 690 620 690 450 793 450)
(points 7 267 430 290 430 290 530 280 530 280 570 370 570 370 590)
(points 9 267 430 290 430 290 530 280 530 280 570 310 570 310 630 370 630 370 650)
(connect D8:1 D12:1
(points 4 500 560 530 560 530 600 550 600)
(connect D9:1 D12:2
(points 4 500 590 520 590 520 610 550 610)
(points 4 414 600 430 600 430 620 550 620)
(points 4 414 660 430 660 430 630 550 630)
(points 2 160 132 160 252)
(points 3 205 280 240 280 240 417)
(connect D1:0 D16:0
(points 2 1020 503 1020 550)
(points 5 205 280 230 280 230 140 280 140 280 157)
(points 3 307 170 380 170 380 202)
(stackingOrder 2 1 7 15 8 9 12 0 3 4
16 13 14 10 11 6 5 18 17)
(titleBg "Gray")
(titleFg "Black")
(numberFormats
(realFormat standard)
(realSigDigits 4)
(realRadixSpec 4)
(integerBase decimal)
Date: Fri, 26 Jul 1996 15:59:20 -0600
To: Stan Bischof <stanb@hpnmrsb2.sr.hp.com>
Subject: Re: VRF- "silent" DOS command call?
Have you tried to run in minimized. It's a selectable setup in the Execute
PC object.
Bob Seiler
Date: Fri, 26 Jul 1996 16:01:11 -0600
P.S you will find the minimize in the Run Style. Click the arrow and see if
it's there.
Bob
Return-Path: <stanb@hpnmrsb2.sr.hp.com>
To: hpvxd_xc@hpislsup.lvld.hp.com
> it's there.
> Bob
OK I'm all set for the moment. Between the "minimize" and custom pif file
hints I can bring in a directory listing OK. Still very clumsy to have to
pop up an icon whenever I want to do this however!
Such is the DOS world I suppose.
Two further questions:
(1) Is it a big deal to write a C program that can do the directory
listing? That way I could have a compiled function that presumably
wouldn't have to open another window.
(2) How does this operation change when I move to Win 95 or NT?
thanks
Stan
> By for now.
> Henrik Grevelund
Sir:
[%%] regards -- gvg
(saveFormat "2.0")
(veerev "3.2")
(SaveCF no)
(filterNAN 0)
(name "Untitled")
(implementation
(locked no)
(trigMode deg)
(nextID 22)
(interface
(input 1
(name "Scale")
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(optional yes)
(input 4
(name "Max")
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(outputType scalar)
(component 1 YPLOT
(interface
(input 1
(name "Trace1")
(lock constraints)
(input 2
(type control)
(name "Scales")
(requires
(datatype Record)
(optional yes)
(implementation
(tracePin 1)
(graphMode strip)
(interface
(output 1
(name "Func")
(implementation
(function Sine)
(frequency 1000)
(amplitude 1)
(dcOffset 0)
(phaseShift 0)
(numPoints 1024)
(interval 0.02)
(degRad Deg)
(errorOnAlias 1)
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "X")
(initValue Text
(data "")
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "M345linger")
(initValue Text
(data "")
(component 5 SLIDER
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 14651.163)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(component 6 SLIDER
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 28430.233)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(name "JCT")
(interface
(input 1
(name "A")
(input 2
(name "B")
(output 1
(name "Data")
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "y")
(initValue Text
(data "")
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "M345linger")
(initValue Text
(data "")
(interface
(output 1
(name "Real")
(implementation
(value Real
(data -1.744)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 8.023)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(interface
(input 1
(name "Scale")
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(optional yes)
(input 4
(name "Max")
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(outputType scalar)
(interface
(output 1
(name "Continuous")
(interface
(output 1
(name "Go")
(implementation
(component 19 NEXT
(interface
(output 1
(name "Go")
(implementation
(implementation
(comp code 0)
(configuration
(connect D3:1 D0:1)
(connect D4:1 D0:2)
(connect D5:1 D0:3)
(connect D6:1 D0:4)
(connect D2:1 D1:1)
(connect D7:1 D1:2)
(connect D0:1 D7:1)
(viewFor -1
(active detail)
(detail
(configuration
(viewFor 0
(active icon)
(icon
(detail
(terminals on)
(viewFor 1
(active detail)
(icon
(detail
(gridType off)
(scale 0
(name "M345linger")
(pen 9)
(show 1)
(trace 0 onScale 0
(name "Trace1")
(pen 4)
(lineType 1)
(pointType 0)
(stepSize 1)
(trackingEnabled 1)
(viewFor 2
(active icon)
(icon
(detail
(terminals on)
(viewFor 3
(active icon)
(icon
(detail
(viewFor 4
(active icon)
(icon
(detail
(viewFor 5
(active icon)
(icon
(detail
(layout vertical)
(fastmode off)
(viewFor 6
(active icon)
(icon
(detail
(layout vertical)
(fastmode off)
(viewFor 7
(active icon)
(icon
(detail
(terminals on)
(viewFor 8
(active icon)
(icon
(detail
(viewFor 9
(active icon)
(icon
(detail
(viewFor 10
(active icon)
(icon
(detail
(layout vertical)
(fastmode off)
(viewFor 11
(active icon)
(icon
(detail
(layout vertical)
(fastmode off)
(viewFor 12
(active icon)
(icon
(detail
(terminals on)
(viewFor 15
(active detail)
(icon
(detail
(title off)
(viewFor 17
(active icon)
(icon
(detail
(terminals on)
(viewFor 18
(active detail)
(icon
(detail
(title off)
(viewFor 19
(active icon)
(icon
(detail
(terminals on)
(viewFor 20
(active detail)
(icon
(detail
(title off)
(viewFor 21
(active icon)
(icon
(detail
(connect D3:1 D0:1
(connect D4:1 D0:2
(connect D5:1 D0:3
(connect D6:1 D0:4
(connect D2:1 D1:1
(connect D7:1 D1:2
(connect D14:1 D2:0
(connect D15:1 D5:0
(connect D15:1 D6:0
(connect D0:1 D7:1
(connect D12:1 D7:2
(connect D8:1 D12:1
(connect D9:1 D12:2
(connect D1:0 D16:0
(titleBg "Gray")
(titleFg "Black")
(numberFormats
(realSigDigits 4)
(realRadixSpec 4)
PC object.
Bob Seiler
it's there.
Bob
> it's there.
> Bob
thanks
Stan
