VRf-Number_Formats
Question asked by VRFuser on Feb 2, 1996
to:   Robert Seiler / VRf
date: Friday, 02 February 1996 1603 MST
> From: Robert Seiler
> AlliedSignal Aerospace
> Phoenix, Arizona
> Subject: Truncation of trailing zeros.
> I am using a real constant to pass values into a test module which contain
> trailing zeros ie: 13.000, 13.500. When the values are displayed to the user
> VEE truncates the zeros. I've tried placing spaces after the zeros but still
> the displayed value drops them. Does anybody know of a way I can keep the
> zeros. It will avoid major confusion to the end user.
> Thanks
> Bob Seiler
Sir:
Not exactly following this ... what are you displaying the data values in?
If you are using an Alphanumeric, just go to the object menu, select
"Edit Properties -> Number", disable "Global Format", specify Decimal /
Fixed / 3 Fractional Digits.
If you have some more subtle problem in mind, let us know, I am sure we can
find a way to skin this cat.
[<>] regards -- gvg
