In message <199607291600.MAA02329@naic.edu>, David Goldbrenner
<goldbren@husc.harvard.edu> writes
>I have to use From String to turn it into an
>integer. It then plots, but it appears as gazillions of seconds, which
>isn't useful. Is there any way I can plot text labels on the x axis? Thanks
>alot.
> Dave
>David H. Goldbrenner
>Arecibo Observatory, Puerto Rico
>goldbren@fas.harvard.edu
Hi Dave
One thing you could do is get the gazillion time of the *first*
measurement by using 'From String'-> 'To Real' and then subtract that
constant value from the time of every measurement taken.
The result will be that your X scale will have 0 as it's first value and
all time values will be relative to zero time; ie the start of the test.
Hope this helps.
Gerry Murray
Gerry@claycon.demon.co.uk
>alot.
> Dave
Hi Dave
Hope this helps.
Gerry Murray
