> Hi all:
> I have detected some problems using the E2050 LAN/HPIB gateway within VEE in
> HP-UX environment.
> Define an instrument which gateway is the E2050 and write a program in order
> to acquire data in a continuos cycle. While the program runs disconnect the
> LAN/HPIB gateway from the LAN for a while until the application detects a
> timeout. Re-connect the LAN/HPIB gateway to the network. The application
> should reausume the acquisition cycle but it shouldn't. Now the error 920
> arises and the following errors appear on the hpterm window:
> ilan <> Error 15, lan_read_1 : RPC_TIMED_OUT
> ilan <> Error 15, lan_clear_1 : RPC_TIMED_OUT
> ilan <> Error 15, lan_lock_1 : RPC_TIMED_OUT
> The only way I found to solve the situation is to quit the VEE environment
> and start agin VEE, load and run the program.
> Does anyone a fine way to work around this problem without leaving VEE and
> re-start.
> Regards.
Juan,
The solution is simple: DONT DISCONNECT YOUR GATEWAY.
And if you do, you should be able to restart your VEE-model
without problem. However, an old session on your gateway may
block normal operation. Log in to your gateway via
telnet, and check for such blocking sessions. You can easily
reboot/reset your gateway if such sessions exist.
Kind regards,
Frank
| Frank Bouwman | |
| Philips Research Labs | Phone +31 40 27 43640 |
| VLSI Design Automation & Test | Fax +31 40 27 44657 |
| WAY4.101, BOX WAY41 | |
| Prof. Holstlaan 4 |-------------------------------------+
| 5656 AA Eindhoven | bouwman@natlab.research.philips.com |
| The Netherlands | bouwman@nlwayhp (Philips SERI) |
| http://130.139.187.36:8080/home/bouwman ... lcome.html |
> Hi all:
> HP-UX environment.
> re-start.
> Regards.
Juan,
Kind regards,
Frank
| Frank Bouwman | |
HP-UX environment.
re-start.
Regards.
Juan Vera <jvera@mdr.inisel-espacio.es>
Indra Espacio S.A
