At 10:28 15/03/97 +0800, you wrote:
>Dear Juan Carlos Martin:
>Thank you for your such fast respond. I also want to use socket object from
VEE.
>But could you give your more detail explaination? I do not know whether you
are familiar with the HP82000, What I want to do on the VEE side is
>* remote controlling HP382 workstation to download pin, timing, vectors to
the hardware
>* remote controlling hp382 workstation to execute the test rountine
>I do not know whether I can implement the above function by using socket
object. I think I must implement the server on workstation to reply respond
of VEE, right?
>Welcome further suggestions
>Yin
Hello again Yin,
First of all, I would like to say you that I have no experience with HP8200.
However, until I can see, you have two connections:
1) The data acquisition, that is the connection between your HP8200 and
your WS HP382 .
2)The connection between your workstation HP382 and your PC with Windows 95.
I think the message of Frank Bouwman was dedicated to the connection 1) by
means of a shared C library (I think in UNIX) to be used in the data
acquisition.
On the other hand, I think you want to monitor and control this equipment by
means of a PC. It is in this connection in which you could use sockets. For
this, the only you need (and you have it) is a LAN with TCP/IP protocol.
You only need a bidirectional socket with a structure client/server where
your PC is the client. However, to install a server using VEE is not easy.
That is, VEE does not include the "listen" capability (well, it is included
if you put a timeout of 0 -infinite-, but then, your program is blocked, and
your VEE command buttons also). Therefore, you can avoid this by means read
the IOSTAT: that is, if a data are in the socket it reads 1, otherwise 0.
|On Cycle 1 |-+
v
| (To/)From socket |
|Bind Port 5001 |
|Host name HP382|
|Timeout 100m | +-----------+ +------+
+------------------------+ | If x==0 |---->| next |
|READ IOSTAUS DATAREADY x|--------->| |-+ +------+
v
| (To/)From socket |
|Bind Port 5001 |
|Host name HP382|
|Timeout 100m |--+ Data command
|READ TEXT x STR | |
| | Objects |
+->| to manage |-----------+
| command | |
| | To(/From) socket |
| |Bind Port 5001 |
| |Host name HP382|
| |Timeout 100m |
+----->|WRITE TEXT a STR |
The client part (your PC) is easier. You only write and wait for a while (a
timeout different from the to/from socket timeout) to read. If data is not
received it means a communication failure.
| To(/From) socket |
|Connect Port 5001 |
Command |Host name PC |
a |Timeout 100m |
+---->|WRITE TEXT a EOL |
v
|Objects which |
|implements a +----------------+
|Loop for timeout| |
v
| (To/)From socket |
|Connect Port 5001 |
|Host name PC |
|Timeout 100m |--> Data status
+-----------------------+ or command OK
|READ TEXT x STR |
I have to design a loop for a timeout defined by you.
Moreover, you could include error pint to/from socket to see a loss of
connection or different problems.
I thinks this is the start point to use sockets in VEE.
Is it a help for you?
King regards,
______________________________________________________
Juan Carlos Martin
E-mail : jcmar@mdr.indra-espacio.es
Phone : 34-1-3963995
Fax : 34-1-3963912
Earth Stations Department
INDRA ESPACIO / MADRID /SPAIN
VEE.
the hardware
of VEE, right?
>Yin
Hello again Yin,
your WS HP382 .
acquisition.
|On Cycle 1 |-+
v
| (To/)From socket |
|Bind Port 5001 |
|Host name HP382|
v
| (To/)From socket |
|Bind Port 5001 |
|Host name HP382|
|READ TEXT x STR | |
| | Objects |
| command | |
| | To(/From) socket |
| |Bind Port 5001 |
| |Host name HP382|
| |Timeout 100m |
| To(/From) socket |
|Connect Port 5001 |
a |Timeout 100m |
v
|Objects which |
|Loop for timeout| |
v
| (To/)From socket |
|Connect Port 5001 |
|Host name PC |
|READ TEXT x STR |
King regards,
Juan Carlos Martin
Fax : 34-1-3963912
>Dear Sirs:
>I have one PC running HP VEE 3.21 on Windows 95 platform. Also, I have one
HP82000 integrated circuit evaluation system which is controlled by HP382
workstation running HP-UX 8.0. I want to program testflow with HP VEE to
implement remote control to test wafer automatically. We program testflow
with HP-BASIC that built in the HP82000 application software at present
stage. The workstaion and PC have been connected by LAN runing TCP/IP
protocol. I wonder if it is possible.
>Any sugestion are most welcome.
>Yin
Hello Yin,
I think you have two possibilities: to use NFS or sockets (It seems that I
am always talking about sockets).
If you use NFS, probably you have to buy a software product to perform it (I
do not know if it is included in windows 95). In this way you could have
some directories (or user accounts) which are shared by both systems. You
get information writing and reading files in those areas.
If you use sockets, you already have the communication. If the application
is not critical and without time constraints, you can use the "to/from
socket" object from VEE.
I hope this help you,
Juan Carlos Martin
Fax : 34-1-3963912
