Hi all,
Regarding the question from Pierre-Eric DEREUX:
I have experienced the "Dreaded RED BOX" many times
and have had identical results - my file was irrepairably
destroyed.
It did not seem to have anything to do with file size.
It usually turned out to be something I did wrong
like trying to write from an external library of
compiled functions into VEE data space (where
there was not enough space reserved).
This also is probably a legitimate segmentation fault.
In order to keep my sanity while trying to find
out what was wrong I did the following:
1. Edit the VEE file - save it under a new name
2. Run it
3. If it is destroyed by the "Dreaded RED BOX" - go back to the
previously saved file.
This way, nothing was lost when my file was destroyed.
I had to do this quite a few times before I found the problem.
Good hunting
Rob Marquardt
System Test Engineering
Rockwell Automation / Allen-Bradley
Milwaukee, Wisconsin, USA
***** Original question follows: *****
2. I've experienced strange behavior with HP VEE 3.21 :
- first, while working on a "big" application, I got a red window
saying
"SERIOUS ERROR Internal error : Segmentation violation (signal=11)
...Error
Number 979". I clicked the OK button, and as adviced, I tried to
save
my
file with a new name.
- then I got and other message "SERIOUS ERROR Internal error : "ID
Number"
sent to freed object ... Error Number 999", which reappeared each
time
I
clicked the OK button.
- I clicked on the other button EXIT and get "SERIOUS ERROR Internal
error :
Message 'Context' sent to freed object ... Error number 999"
- then I shut down the system, closing all the other applications.
- after relogging, it was impossible to load my prevous file, I got
the
messages
"CAUTION Error occured during load of device userobject
Argument was not found (file=c:...) File : c:... near line 10857"
- clicking OK, I had "CAUTION Error occured during load of device
userfunction End of file or no data found while searching for block
closure...
near line 1600"
- clicking OK, the same message again for the line 70.
- clicking OK, an Error Message (End of file or data not found while
searching for block closure)
Strange, isn't it ?
Is my file too big ? Is there any known limitations in the number of
global
variables, userobjects, userfunctions, objects, or any others problems
Thanks for giving attention !
Pierre-Eric DEREUX
Bell Helicopter Textron Canada
E & S Lab
Tel : (514) 971 6731
E Mail : PDereux@aol.com
destroyed.
2. Run it
Good hunting
Rob Marquardt
saying
...Error
save
my
Number"
time
I
error :
the
messages
closure...
near line 1600"
Strange, isn't it ?
global
Pierre-Eric DEREUX
E & S Lab
Some questions for those using HP VEE v 3.21 under windows NT 4.0 :
1. On a previous application, we were running HP VEE for windows 3.1, and a
DDE server developped in Borland C++ v 4.0 to communicate with National
Instruments boards (AT DIO 32F) via ISA bus.
I've tried to run this DDE server on a new station (windows NT 4.0) with
HP
VEE 3.21 and - of course - it doesn't work.
I'm looking for some work around to reuse this DDE server (configuring
properly windows NT 4.0 ...?) , or, if not possible, to drive these
boards directly
with HP VEE ...
Have you smart solutions ?
- first, while working on a "big" application, I got a red window saying
...Error
Number 979". I clicked the OK button, and as adviced, I tried to save
my
Number"
sent to freed object ... Error Number 999", which reappeared each time
I
error :
- after relogging, it was impossible to load my prevous file, I got the
messages
closure...
near line 1600"
Strange, isn't it ?
Is my file too big ? Is there any known limitations in the number of global
variables, userobjects, userfunctions, objects, or any others problems ???
Pierre-Eric DEREUX
E & S Lab
