vrf How to avoid excel shutting down when VEE is being closed, and wh
Question asked by VRFuser on Nov 21, 2001
I'm using VEE to generate an excelsheet, but I have a couple of small
questions regarding that.
First problem:
If I close down VEE after the sheets have been created, Excel closes as
well, how do I avoid this.
Second problem:
When excel starts up, and the sheets are created the "save as" button is
crayed out the only thing I can do if I want to save the sheet from excel is
to select "Save copy as"
I know there is a method to save the sheets from VEE, but I would like to be
able to save the sheets from Excel.
Thanks in advance
Kenth Jensen
