send q VRf-VEEDOC_Bugs ww vrf blmast@itt.com
to: Brian Mast / VRf
date: Monday, 19 August 1996 1540 MDT
> I get a "closure not found" message when running VEEDOC on some files.
> What does this message mean and what causes it? The files that the
> message occurs on are large (about 7 Meg). Is there a limit to the
> file size that VEEDOC can handle? I am running VEE 3.12.
Sir:
Not good news:
% There is no specific limit on file size with VEEDOC, though of course
available system memory is a concern.
% According to the lab guys, the error message means VEEDOC found a
VEE construct it did not understand and which blew its simple little
mind.
% Furthermore, VEEDOC was a rather poorly-implemented tool and was strongly
prone to such errors. As of VEE 3.2, much more effective functionality
was incorporated in VEE as the File->Save Documentation menu selection.
No further work on VEEDOC itself is planned.
Not sure where to go from here, sir. Please stay in touch.
[<>] regards -- gvg
Sir:
Not good news:
mind.
[<>] regards -- gvg
