to: Gerry Murray / VRf
date: Monday, 13 May 1996 0828 MDT
> 1. I notice in the HP catalogue for 1996, there is a 'HP Instrument
> Driver' graphic symbol alongside the HP70820A so I'm sure there will
> be a driver for that somewhere in the HP collective conciousness. No
> such symbols present alongside the HP83480. The others not listed yet.
Plug&Play drivers have put matters into something of a state of confusion ...
rather like breaking things apart and then reassembling them into a different
direction. Bear with us, I think we'll have a better solution than we did
with the old drivers if we can surmount the obstacles.
> 2. In my limited experience of VEE, I've found it convenient to have
> the driver available for the equipment in the early stages but later
> on, speed and size considerations have pressed me in to creating
> libraries of direct I/O userfunctions. Even using 'Component I/O'
> sections of the instrument drivers has it's problems. In my experience
> of driving 25 different pieces of equipment, direct I/O has always
> turned out to be the final and best option.
This actually is the common experience with drivers. They are useful for
quick turnaround projects but when you have to fine-tune performance, it is
useful to turn off the autopilot and take over the controls.
> Hope this helps, or, at best, doesn't hinder.
> Regards
> Gerry Murray
> ___________________ Reply Separator _________________________________
> Dear VEE users,
> I am desperately seeking VEE drivers for :
> HP70841B Pattern generator
> HP70820A Microwave Transition Analyzer HP70842B Error Detector
> HP83480A Communications Analyzer
> Thanks for any response.
> Maurice.Verreck@nym.sc.philips.com
> Philips Semiconductors
> Product Group Communications & Multimedia Nijmegen, The Neterlands.
> Regards
> Gerry Murray
> Dear VEE users,
2 points that may be of help
Regards
Gerry Murray
Dear VEE users,
