VRf-Scrollbars
Question asked by VRFuser on Aug 22, 1996
send q VRf-Scrollbars grevelund_h vrf
to:   Henrik Grevelund
date: Thursday, 22 August 1996 1624 MDT
    HG:  LET ME KNOW IF YOU GET THIS.  Site email is having some troubles.
Sir:
Concerning your problem with VEE not redrawing the scroll bars after being
overlaid by a pop-up:
> I have made a little example, and i tryed to examine the problem further.
> The Userobject must be in Panel view and must exceed the right and bottom
> edge. So that the scrollbars show.
> Start the program and press OK to start the object. While it is showing
> the data, then click the mouse on it and move it around, beyond the egde.
> When you release the mousebottom the scrollbars will not be redrawn.
> !! about size i only use a 15" screen.
> otherwise it's a V743/64, 64 MB ram, HP-UX 9.05, VEE 3.20
I see it sometimes ... just press CTRL-R and it will be redrawn.
I will submit this as a low-weight bug.
(saveFormat "2.0")
(date "Tue 20/Aug/1996 09:03:53 METDST")
(veerev "3.2")
(platform "HP9000s700")
(SaveCF no)
(filterNAN 0)
(component 0 ROOTCONTEXT
(name "Untitled")
(implementation
  (locked no)
  (trigMode deg)
  (nextID 8)
  (component 0 START25
  (component 1 REPEATUNTILBREAK
   (interface
     (output 1
      (name "Continuous")
      (lock name constraints)
  (component 2 CONFIRM25
   (interface
     (output 1
      (name "Go")
   (implementation
     (component enterButton yes)
     (component escapeButton yes)
  (component 7 CONTEXT
   (name "UserObject")
   (implementation
     (locked no)
     (trigMode deg)
     (nextID 4)
     (popupMoveable)
     (component 0 YPLOT
      (name "Strip Chart")
      (interface
       (input 1
        (name "Trace1")
        (lock constraints)
      (implementation
       (tracePin 1)
       (graphMode strip)
       (bufferSize 100000)
     (component 1 VFUNCTIONGENERATOR
      (interface
       (output 1
        (name "Func")
      (implementation
       (function Cosine)
       (frequency 1000)
       (amplitude 1)
       (dcOffset 0)
       (phaseShift 0)
       (numPoints 256)
       (interval 0.02)
       (degRad Deg)
       (errorOnAlias 1)
     (component 2 FORCOUNT
      (interface
       (output 1
        (name "Count")
      (implementation
       (count 100)
     (component 3 NOTE
      (implementation
       (text2 3
          "Make this Object bigger than"
          "your screen both in Panel "
          "and detail view."
     (configuration
      (connect D1:1 D0:1)
      (connect D2:1 D1:0)
     (ShowOnExecPanel
      (geometry 14 290 961 668)
      (panel
       (geometry 22 87 957 647)
       (widget 0 detail
        (title on)
        (borderStyle flat)
        (geometry 144 137 293 262)
        (displayMode scrollGraph)
        (graphType cartesian)
        (gridType off)
        (scale 0
          (name "Y name")
          (domainName "X name")
          (pen 9)
          (show 1)
          (range 0 1 4 linear)
        (domain 0 20 4 linear)
        (trace 0 onScale 0
          (name "Trace1")
          (pen 4)
          (lineType 1)
          (pointType 0)
        (stepSize 1)
        (trackingEnabled 1)
  (configuration
   (connect D0:0 D1:0)
   (connect D1:1 D2:0)
   (connect D2:1 D3:0)
(viewFor -1
  (active detail)
  (detail
   (geometry 0 53 1002 674)
   (configuration
     (viewFor 0
      (active detail)
      (icon
      (detail
       (geometry -4 80 49 20)
      (title off)
     (viewFor 1
      (active icon)
      (icon
       (geometry 7 135 86 51)
       (iconImage "loop.icn")
      (detail
      (terminals on)
     (viewFor 2
      (active detail)
      (icon
      (detail
       (geometry 146 190 49 20)
      (title off)
     (viewFor 7
      (active detail)
      (icon
      (detail
       (geometry 21 254 1219 713)
       (configuration
        (viewFor 0
          (active icon)
          (icon
           (geometry 524 449 88 51)
           (iconImage "display.icn")
          (detail
           (geometry 422 343 293 262)
           (gridType off)
           (scale 0
            (name "Y name")
            (pen 9)
            (show 1)
           (trace 0 onScale 0
            (name "Trace1")
            (pen 4)
            (lineType 1)
            (pointType 0)
           (stepSize 1)
           (trackingEnabled 1)
        (viewFor 1
          (active detail)
          (icon
           (iconImage "virtual.icn")
          (detail
           (geometry 83 397 220 175)
          (terminals on)
        (viewFor 2
          (active detail)
          (icon
          (detail
           (geometry 82 319 113 31)
        (viewFor 3
          (active detail)
          (icon
           (iconImage "notepad.icn")
          (detail
           (geometry 649 306 282 108)
           (editing enabled)
        (connect D1:1 D0:1
          (points 4 345 484 370 484 370 474 521 474)
        (connect D2:1 D1:0
          (points 5 197 334 208 334 208 364 198 364 198 376)
       (stackingOrder 1 2 0 3)
      (terminals on)
     (connect D0:0 D1:0
      (points 4 20 102 20 110 50 110 50 132)
     (connect D1:1 D2:0
      (points 3 95 160 170 160 170 187)
     (connect D2:1 D3:0
      (points 3 197 200 630 200 630 227)
   (stackingOrder 0 1 2 3)
  (titleBg "Gray")
  (titleFg "Black")
  (numberFormats
   (realFormat standard)
   (realSigDigits 4)
   (realRadixSpec 4)
   (integerBase decimal)
