Hi Heiko
I've attached a vee file that sets up X vs Y scale names and ranges.
Just cut below the line and put it into a file called scaldemo.vee and you
should be able to run it.
Hope it helps.
Regards
Gerry Murray
------- Cut Here -----------------------
#! C:VEE3/vee -r
(saveFormat "1.2")
(date "Fri 24/May/1996")
(SaveCF "no")
(filterNAN 0)
(component 0 "ROOTCONTEXT"
(name "Untitled")
(interface
(implementation
(retainGlobals YES)
(locked no)
(trigMode deg)
(nextID 15)
(component 0 "TORECORD"
(description 1 4
Build the record of scales data.
(interface
(sequence in)
(sequence out)
(input 1
(name "Scale")
(requires
(datatype Text)
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(requires
(datatype Real)
(optional yes)
(input 4
(name "Max")
(requires
(datatype Real)
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(component outputType scalar)
(views
(icon
(origin 326 364)
(extent 89 52)
(iconImage "build.icn")
(detail
(origin 119 249)
(extent 93 82)
(terminals on)
(active detail)
(component 1 "XYPLOT"
(name "X vs Y Plot")
(interface
(sequence in)
(sequence out)
(input 1
(name "XData")
(lock constraints)
(input 2
(name "YData1")
(lock constraints)
(input 3
(type control)
(name "Scales")
(tag "ScalesRecord")
(requires
(datatype Record)
(lock name constraints)
(optional yes)
(implementation
(component clearAtPrerun 1)
(component clearAtActivate 1)
(component tracePin 2)
(component graphMode rectangular)
(views
(icon
(iconImage "display.icn")
(detail
(origin 477 64)
(extent 296 272)
(displayMode scrollGraph)
(graphType cartesian)
(gridType grid)
(scale 0
(name "Voltage")
(domainName "Time")
(pen 9)
(show 1)
(range 0 0.6 4 linear)
(domain -10 8 4 linear)
(trace 0 onScale 0
(name "YData1")
(pen 4)
(lineType 1)
(pointType 0)
(terminals on)
(active detail)
(component 2 "LITERALCONSTANT"
(name "Text")
(interface
(sequence in)
(sequence out)
(output 1
(name "Text")
(implementation
(component value Text
(data "X" )
(component initValue Text
(data "" )
(views
(icon
(origin -5 242)
(extent 31 16)
(detail
(origin 27 175)
(extent 67 30)
(active icon)
(component 3 "LITERALCONSTANT"
(name "Text")
(interface
(sequence in)
(sequence out)
(output 1
(name "Text")
(implementation
(data "Time" )
(data "" )
(views
(icon
(origin -5 272)
(extent 31 16)
(detail
(origin 15 254)
(extent 91 32)
(active icon)
(component 4 "CONSTANT"
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(component value Real
(data 0 )
(component initValue Real
(data 0 )
(views
(icon
(detail
(origin 216 85)
(extent 69 30)
(showFormat real)
(active detail)
(component 5 "CONSTANT"
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data 0 )
(data 0 )
(views
(icon
(detail
(origin 226 155)
(extent 69 30)
(showFormat real)
(active detail)
(component 6 "CONSTANT"
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data -10 )
(data 0 )
(views
(icon
(origin -16 312)
(extent 33 16)
(detail
(origin 166 275)
(extent 69 30)
(showFormat real)
(active icon)
(component 7 "CONSTANT"
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data 10 )
(data 0 )
(views
(icon
(origin -6 352)
(extent 33 16)
(detail
(origin 176 315)
(extent 69 30)
(showFormat real)
(active icon)
(component 8 "TORECORD"
(description 1 4
(interface
(sequence in)
(sequence out)
(input 1
(name "Scale")
(requires
(datatype Text)
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(requires
(datatype Real)
(optional yes)
(input 4
(name "Max")
(requires
(datatype Real)
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(views
(icon
(origin 326 364)
(extent 89 52)
(detail
(origin 89 419)
(extent 93 82)
(terminals on)
(active detail)
(component 9 "CONSTANT"
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data 0.6 )
(data 0 )
(views
(icon
(origin -36 522)
(extent 33 16)
(detail
(origin 136 485)
(extent 69 30)
(showFormat real)
(active icon)
(component 10 "CONSTANT"
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data 0 )
(data 0 )
(views
(icon
(origin -46 482)
(extent 33 16)
(detail
(origin 116 445)
(extent 69 30)
(showFormat real)
(active icon)
(component 11 "LITERALCONSTANT"
(name "Text")
(interface
(sequence in)
(sequence out)
(output 1
(name "Text")
(implementation
(data "Voltage" )
(data "" )
(views
(icon
(origin -35 442)
(extent 31 16)
(detail
(origin 125 404)
(extent 91 32)
(active icon)
(component 12 "LITERALCONSTANT"
(name "Text")
(interface
(sequence in)
(sequence out)
(output 1
(name "Text")
(implementation
(data "Y" )
(data "" )
(views
(icon
(origin -35 412)
(extent 31 16)
(detail
(origin 137 375)
(extent 67 30)
(active icon)
(component 13 "JUNCTION"
(name "JCT")
(interface
(input 1
(name "A")
(input 2
(name "B")
(output 1
(name "Data")
(implementation
(views
(icon
(origin 306 288)
(extent 29 25)
(detail
(terminals on)
(active icon)
(component 14 "START25"
(interface
(sequence out)
(implementation
(views
(icon
(detail
(origin -63 99)
(extent 47 22)
(title off)
(active detail)
(configuration
(connect D14:0 D0:0)
(connect D2:1 D0:1)
(connect D3:1 D0:2)
(connect D6:1 D0:3)
(connect D7:1 D0:4)
(connect D4:1 D1:1)
(connect D5:1 D1:2)
(connect D13:1 D1:3)
(connect D8:0 D4:0)
(connect D4:0 D5:0)
(connect D0:0 D8:0)
(connect D12:1 D8:1)
(connect D11:1 D8:2)
(connect D10:1 D8:3)
(connect D9:1 D8:4)
(connect D0:1 D13:1)
(connect D8:1 D13:2)
(views
(detail
(origin 0 24)
(extent 800 538)
(configuration
(connect D14:0 D0:0
(Point -40 123)
(Point -40 140)
(Point 170 140)
(Point 170 228)
(connect D2:1 D0:1
(Point 28 250)
(Point 50 250)
(Point 50 260)
(Point 66 260)
(connect D3:1 D0:2
(Point 28 280)
(Point 66 280)
(connect D6:1 D0:3
(Point 19 320)
(Point 50 320)
(Point 50 300)
(Point 66 300)
(connect D7:1 D0:4
(Point 29 360)
(Point 50 360)
(Point 50 330)
(Point 60 330)
(Point 60 320)
(Point 66 320)
(connect D4:1 D1:1
(Point 287 100)
(Point 310 100)
(Point 310 110)
(Point 414 110)
(connect D5:1 D1:2
(Point 297 170)
(Point 320 170)
(Point 320 200)
(Point 414 200)
(connect D13:1 D1:3
(Point 337 300)
(Point 360 300)
(Point 360 290)
(Point 414 290)
(connect D8:0 D4:0
(Point 140 503)
(Point 140 520)
(Point 370 520)
(Point 370 210)
(Point 190 210)
(Point 190 40)
(Point 250 40)
(Point 250 64)
(connect D4:0 D5:0
(Point 250 117)
(Point 260 134)
(connect D0:0 D8:0
(Point 170 333)
(Point 170 350)
(Point 140 350)
(Point 140 398)
(connect D12:1 D8:1
(Point -2 420)
(Point 20 420)
(Point 20 430)
(Point 36 430)
(connect D11:1 D8:2
(Point -2 450)
(Point 36 450)
(connect D10:1 D8:3
(Point -11 490)
(Point 10 490)
(Point 10 480)
(Point 20 480)
(Point 20 470)
(Point 36 470)
(connect D9:1 D8:4
(Point -1 530)
(Point 20 530)
(Point 20 490)
(Point 36 490)
(connect D0:1 D13:1
(Point 274 290)
(Point 303 290)
(connect D8:1 D13:2
(Point 244 460)
(Point 290 460)
(Point 290 310)
(Point 303 310)
(stackingOrder 1 4 5 3 2 0 13 11 9 8
12 10 14 6 7)
(active detail)
(numberFormats
(realFormat standard)
(realSigDigits 4)
(realRadixSpec 4)
(integerBase decimal)
Hope it helps.
Regards
Gerry Murray
#! C:VEE3/vee -r
(saveFormat "1.2")
(SaveCF "no")
(filterNAN 0)
(name "Untitled")
(interface
(implementation
(retainGlobals YES)
(locked no)
(trigMode deg)
(nextID 15)
(description 1 4
(interface
(sequence in)
(sequence out)
(input 1
(name "Scale")
(requires
(datatype Text)
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(requires
(datatype Real)
(optional yes)
(input 4
(name "Max")
(requires
(datatype Real)
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(views
(icon
(origin 326 364)
(extent 89 52)
(detail
(origin 119 249)
(extent 93 82)
(terminals on)
(active detail)
(interface
(sequence in)
(sequence out)
(input 1
(name "XData")
(lock constraints)
(input 2
(name "YData1")
(lock constraints)
(input 3
(type control)
(name "Scales")
(requires
(datatype Record)
(optional yes)
(implementation
(views
(icon
(detail
(origin 477 64)
(extent 296 272)
(gridType grid)
(scale 0
(name "Voltage")
(domainName "Time")
(pen 9)
(show 1)
(trace 0 onScale 0
(name "YData1")
(pen 4)
(lineType 1)
(pointType 0)
(terminals on)
(active detail)
(name "Text")
(interface
(sequence in)
(sequence out)
(output 1
(name "Text")
(implementation
(data "X" )
(data "" )
(views
(icon
(origin -5 242)
(extent 31 16)
(detail
(origin 27 175)
(extent 67 30)
(active icon)
(name "Text")
(interface
(sequence in)
(sequence out)
(output 1
(name "Text")
(implementation
(data "Time" )
(data "" )
(views
(icon
(origin -5 272)
(extent 31 16)
(detail
(origin 15 254)
(extent 91 32)
(active icon)
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data 0 )
(data 0 )
(views
(icon
(detail
(origin 216 85)
(extent 69 30)
(showFormat real)
(active detail)
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data 0 )
(data 0 )
(views
(icon
(detail
(origin 226 155)
(extent 69 30)
(showFormat real)
(active detail)
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data -10 )
(data 0 )
(views
(icon
(origin -16 312)
(extent 33 16)
(detail
(origin 166 275)
(extent 69 30)
(showFormat real)
(active icon)
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data 10 )
(data 0 )
(views
(icon
(origin -6 352)
(extent 33 16)
(detail
(origin 176 315)
(extent 69 30)
(showFormat real)
(active icon)
(description 1 4
(interface
(sequence in)
(sequence out)
(input 1
(name "Scale")
(requires
(datatype Text)
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(requires
(datatype Real)
(optional yes)
(input 4
(name "Max")
(requires
(datatype Real)
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(views
(icon
(origin 326 364)
(extent 89 52)
(detail
(origin 89 419)
(extent 93 82)
(terminals on)
(active detail)
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data 0.6 )
(data 0 )
(views
(icon
(origin -36 522)
(extent 33 16)
(detail
(origin 136 485)
(extent 69 30)
(showFormat real)
(active icon)
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data 0 )
(data 0 )
(views
(icon
(origin -46 482)
(extent 33 16)
(detail
(origin 116 445)
(extent 69 30)
(showFormat real)
(active icon)
(name "Text")
(interface
(sequence in)
(sequence out)
(output 1
(name "Text")
(implementation
(data "Voltage" )
(data "" )
(views
(icon
(origin -35 442)
(extent 31 16)
(detail
(origin 125 404)
(extent 91 32)
(active icon)
(name "Text")
(interface
(sequence in)
(sequence out)
(output 1
(name "Text")
(implementation
(data "Y" )
(data "" )
(views
(icon
(origin -35 412)
(extent 31 16)
(detail
(origin 137 375)
(extent 67 30)
(active icon)
(name "JCT")
(interface
(input 1
(name "A")
(input 2
(name "B")
(output 1
(name "Data")
(implementation
(views
(icon
(origin 306 288)
(extent 29 25)
(detail
(terminals on)
(active icon)
(interface
(sequence out)
(implementation
(views
(icon
(detail
(origin -63 99)
(extent 47 22)
(title off)
(active detail)
(configuration
(connect D2:1 D0:1)
(connect D3:1 D0:2)
(connect D6:1 D0:3)
(connect D7:1 D0:4)
(connect D4:1 D1:1)
(connect D5:1 D1:2)
(connect D8:0 D4:0)
(connect D4:0 D5:0)
(connect D0:0 D8:0)
(connect D9:1 D8:4)
(views
(detail
(origin 0 24)
(extent 800 538)
(configuration
(connect D14:0 D0:0
(Point -40 123)
(Point -40 140)
(Point 170 140)
(Point 170 228)
(connect D2:1 D0:1
(Point 28 250)
(Point 50 250)
(Point 50 260)
(Point 66 260)
(connect D3:1 D0:2
(Point 28 280)
(Point 66 280)
(connect D6:1 D0:3
(Point 19 320)
(Point 50 320)
(Point 50 300)
(Point 66 300)
(connect D7:1 D0:4
(Point 29 360)
(Point 50 360)
(Point 50 330)
(Point 60 330)
(Point 60 320)
(Point 66 320)
(connect D4:1 D1:1
(Point 287 100)
(Point 310 100)
(Point 310 110)
(Point 414 110)
(connect D5:1 D1:2
(Point 297 170)
(Point 320 170)
(Point 320 200)
(Point 414 200)
(connect D13:1 D1:3
(Point 337 300)
(Point 360 300)
(Point 360 290)
(Point 414 290)
(connect D8:0 D4:0
(Point 140 503)
(Point 140 520)
(Point 370 520)
(Point 370 210)
(Point 190 210)
(Point 190 40)
(Point 250 40)
(Point 250 64)
(connect D4:0 D5:0
(Point 250 117)
(Point 260 134)
(connect D0:0 D8:0
(Point 170 333)
(Point 170 350)
(Point 140 350)
(Point 140 398)
(connect D12:1 D8:1
(Point -2 420)
(Point 20 420)
(Point 20 430)
(Point 36 430)
(connect D11:1 D8:2
(Point -2 450)
(Point 36 450)
(connect D10:1 D8:3
(Point -11 490)
(Point 10 490)
(Point 10 480)
(Point 20 480)
(Point 20 470)
(Point 36 470)
(connect D9:1 D8:4
(Point -1 530)
(Point 20 530)
(Point 20 490)
(Point 36 490)
(connect D0:1 D13:1
(Point 274 290)
(Point 303 290)
(connect D8:1 D13:2
(Point 244 460)
(Point 290 460)
(Point 290 310)
(Point 303 310)
12 10 14 6 7)
(active detail)
(numberFormats
(realSigDigits 4)
(realRadixSpec 4)
Hope it helps.
Regards
Gerry Murray
#! C:VEE3/vee -r
(saveFormat "1.2")
(SaveCF "no")
(filterNAN 0)
(name "Untitled")
(interface
(implementation
(retainGlobals YES)
(locked no)
(trigMode deg)
(nextID 15)
(description 1 4
(interface
(sequence in)
(sequence out)
(input 1
(name "Scale")
(requires
(datatype Text)
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(requires
(datatype Real)
(optional yes)
(input 4
(name "Max")
(requires
(datatype Real)
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(views
(icon
(origin 326 364)
(extent 89 52)
(detail
(origin 119 249)
(extent 93 82)
(terminals on)
(active detail)
(interface
(sequence in)
(sequence out)
(input 1
(name "XData")
(lock constraints)
(input 2
(name "YData1")
(lock constraints)
(input 3
(type control)
(name "Scales")
(requires
(datatype Record)
(optional yes)
(implementation
(views
(icon
(detail
(origin 477 64)
(extent 296 272)
(gridType grid)
(scale 0
(name "Voltage")
(domainName "Time")
(pen 9)
(show 1)
(trace 0 onScale 0
(name "YData1")
(pen 4)
(lineType 1)
(pointType 0)
(terminals on)
(active detail)
(name "Text")
(interface
(sequence in)
(sequence out)
(output 1
(name "Text")
(implementation
(data "X" )
(data "" )
(views
(icon
(origin -5 242)
(extent 31 16)
(detail
(origin 27 175)
(extent 67 30)
(active icon)
(name "Text")
(interface
(sequence in)
(sequence out)
(output 1
(name "Text")
(implementation
(data "Time" )
(data "" )
(views
(icon
(origin -5 272)
(extent 31 16)
(detail
(origin 15 254)
(extent 91 32)
(active icon)
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data 0 )
(data 0 )
(views
(icon
(detail
(origin 216 85)
(extent 69 30)
(showFormat real)
(active detail)
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data 0 )
(data 0 )
(views
(icon
(detail
(origin 226 155)
(extent 69 30)
(showFormat real)
(active detail)
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data -10 )
(data 0 )
(views
(icon
(origin -16 312)
(extent 33 16)
(detail
(origin 166 275)
(extent 69 30)
(showFormat real)
(active icon)
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data 10 )
(data 0 )
(views
(icon
(origin -6 352)
(extent 33 16)
(detail
(origin 176 315)
(extent 69 30)
(showFormat real)
(active icon)
(description 1 4
(interface
(sequence in)
(sequence out)
(input 1
(name "Scale")
(requires
(datatype Text)
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(requires
(datatype Real)
(optional yes)
(input 4
(name "Max")
(requires
(datatype Real)
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(views
(icon
(origin 326 364)
(extent 89 52)
(detail
(origin 89 419)
(extent 93 82)
(terminals on)
(active detail)
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data 0.6 )
(data 0 )
(views
(icon
(origin -36 522)
(extent 33 16)
(detail
(origin 136 485)
(extent 69 30)
(showFormat real)
(active icon)
(name "Real")
(subType "Real")
(interface
(sequence in)
(sequence out)
(output 1
(name "Real")
(implementation
(data 0 )
(data 0 )
(views
(icon
(origin -46 482)
(extent 33 16)
(detail
(origin 116 445)
(extent 69 30)
(showFormat real)
(active icon)
(name "Text")
(interface
(sequence in)
(sequence out)
(output 1
(name "Text")
(implementation
(data "Voltage" )
(data "" )
(views
(icon
(origin -35 442)
(extent 31 16)
(detail
(origin 125 404)
(extent 91 32)
(active icon)
(name "Text")
(interface
(sequence in)
(sequence out)
(output 1
(name "Text")
(implementation
(data "Y" )
(data "" )
(views
(icon
(origin -35 412)
(extent 31 16)
(detail
(origin 137 375)
(extent 67 30)
(active icon)
(name "JCT")
(interface
(input 1
(name "A")
(input 2
(name "B")
(output 1
(name "Data")
(implementation
(views
(icon
(origin 306 288)
(extent 29 25)
(detail
(terminals on)
(active icon)
(interface
(sequence out)
(implementation
(views
(icon
(detail
(origin -63 99)
(extent 47 22)
(title off)
(active detail)
(configuration
(connect D2:1 D0:1)
(connect D3:1 D0:2)
(connect D6:1 D0:3)
(connect D7:1 D0:4)
(connect D4:1 D1:1)
(connect D5:1 D1:2)
(connect D8:0 D4:0)
(connect D4:0 D5:0)
(connect D0:0 D8:0)
(connect D9:1 D8:4)
(views
(detail
(origin 0 24)
(extent 800 538)
(configuration
(connect D14:0 D0:0
(Point -40 123)
(Point -40 140)
(Point 170 140)
(Point 170 228)
(connect D2:1 D0:1
(Point 28 250)
(Point 50 250)
(Point 50 260)
(Point 66 260)
(connect D3:1 D0:2
(Point 28 280)
(Point 66 280)
(connect D6:1 D0:3
(Point 19 320)
(Point 50 320)
(Point 50 300)
(Point 66 300)
(connect D7:1 D0:4
(Point 29 360)
(Point 50 360)
(Point 50 330)
(Point 60 330)
(Point 60 320)
(Point 66 320)
(connect D4:1 D1:1
(Point 287 100)
(Point 310 100)
(Point 310 110)
(Point 414 110)
(connect D5:1 D1:2
(Point 297 170)
(Point 320 170)
(Point 320 200)
(Point 414 200)
(connect D13:1 D1:3
(Point 337 300)
(Point 360 300)
(Point 360 290)
(Point 414 290)
(connect D8:0 D4:0
(Point 140 503)
(Point 140 520)
(Point 370 520)
(Point 370 210)
(Point 190 210)
(Point 190 40)
(Point 250 40)
(Point 250 64)
(connect D4:0 D5:0
(Point 250 117)
(Point 260 134)
(connect D0:0 D8:0
(Point 170 333)
(Point 170 350)
(Point 140 350)
(Point 140 398)
(connect D12:1 D8:1
(Point -2 420)
(Point 20 420)
(Point 20 430)
(Point 36 430)
(connect D11:1 D8:2
(Point -2 450)
(Point 36 450)
(connect D10:1 D8:3
(Point -11 490)
(Point 10 490)
(Point 10 480)
(Point 20 480)
(Point 20 470)
(Point 36 470)
(connect D9:1 D8:4
(Point -1 530)
(Point 20 530)
(Point 20 490)
(Point 36 490)
(connect D0:1 D13:1
(Point 274 290)
(Point 303 290)
(connect D8:1 D13:2
(Point 244 460)
(Point 290 460)
(Point 290 310)
(Point 303 310)
12 10 14 6 7)
(active detail)
(numberFormats
(realSigDigits 4)
(realRadixSpec 4)
