vee defect VXDaa10594 was updated by dougk
Question asked by VRFuser on Oct 16, 1996
Bug VXDaa10594                vee                           Submitted 961017
  DUPLICATE of VXDaa09932                                    Assigned 961017
                              taz.gumby
                                                            Duplicate 961017
  "BEEP busted on win/95- single fixed chime for any setting"
                                        LABORATORY INFORMATION
                                         Assigned engineer: dougk
Detection method: customer use
Platform:         Windows95
Problem severity: 5
SUBMITTER INFORMATION
Submitter:     Stan Bischof
Organization:  HP MID
Address:       stanb@sr.hp.com
************ Dup of VXDaa09932 (Modified 961017 by ddts) ***********
Bug VXDaa09932                vee                           Submitted 960924
  ASSIGNED usability issue                                   Assigned 960924
                              3.21
  "VEE BEEP Object Only Generates Click On Win95"
Platform:         Windows95
Usability weight: 3
Submitter:     Greg Goebel
Organization:  HP MXD
Address:       gvg
************ Problem ************
VEE BEEP Only Generates Click On Win95
* We have had multiple reports of VEE 3.2X not generating a proper BEEP with
the BEEP object (all you get is a click) on Win95 ... examinations of our
systems here seem to confirm this.
The response to this problem from the lab earlier was that this was a
function of the sound hardware on the PC.  However, running the following
QBASIC program generates the expected sounds, so it is clear the PC hardware
is functioning properly.
' PLAY Demo 2
' v1.0 / 08 dec 93 / gvg
' This little DOS QBASIC program demonstrates the PLAY statement
' by playing a familiar tune on the speaker.
S$ = "L16"         ' Default is 1/8 note.
S$ = S$ + "T90"    ' Tempo
S$ = S$ + "MS"     ' Play "music staccato".
S$ = S$ + "O5"     ' Set octave.
' Notes for tune ... beware that an octave starts at C and ends at B.
S$ = S$ + " E D32 C D E D# E C D D D D4"
S$ = S$ + " D C32 B C D C# D B C C C C4"
S$ = S$ + "<G A-32 A A- G A- A A- G >D D D4"
S$ = S$ + "<G A-32 A A- G A- A A- G >E E E4"
S$ = S$ + "<A G# A D8 E8 ML G2 G64"
PLAY S$
END
' *********************** That's All, Folks! ***********************
Please describe the problem you are experiencing below (in more detail
than the single line description), including what you did, what you expected
to happen, and what actually happened:
************ Duplicates ************
# Log of duplicates of this defect
Duplicate: VXDaa10332
Duplicate: VXDaa10594
************ History ************
xddts    960924 092251 Severity submitted as 3 by gvg@lvld.hp.com
xddts    960924 092252 Submitted to vee by gvg@lvld.hp.com
xddts    960924 092306 Enclosure "Problem" added by gvg
xddts    960924 093720 N -> A (Assigned to dougk) by hillr
batchbug 961017 134305 Times-reported incremented because of duplicate - VXDaa10332
batchbug 961017 134346 Times-reported incremented because of duplicate - VXDaa10594
batchbug 961017 101440 Severity submitted as 5 by Stan Bischof
batchbug 961017 101440 Submitted to vee -  by Stan Bischof, from the Web.
xddts    961017 130623 N -> A (Assigned to dougk) by jimbo
xddts    961017 134247 A -> D (VXDaa09932) by dougk
