1 : Yes (I looked at it today, there may be something i can use)
3 : Slower
4 : No (just keep the information level up)
5 : No (If the information is OK, then F... the look's)
6 : No (No reason to do that)
Regarding Prog Design
I have made a program to calculate the Joule.
I consist of a scope picture where The time cursors on the scope determine
what part of the curve to use.
The curve are saved in a Global as an Array with 2000 points.
With a For Range and a formula using <wave_array(a)> a as the counter
it takes about 9 sek. to run true 1500 of points in the array (The ones i Need)
I say in your Letter(Greg) that gahtering of the measurement in an array is
good.
Maybe i just don't understand Vee that good. is there a easier way ?.
A Mindblowing Idea : Could it be possible over the internet to make a
veeprogram developer, so that we can drav some smale programs and ask for help
instead of drawing it in Ascii.
Allright Then ! Have a nice day
___
\___/
Royal Danish Navy
/\_____| |_____/
Henrik Grevelund
mkpkor@inet.uni-c.dk
Mine component work shop
Naval Base Korsoer, Denmark
\______/ \______/
\________/^\________/
3 : Slower
good.
___
\___/
Royal Danish Navy
/\_____| |_____/
Henrik Grevelund
\______/ \______/
