Hye !
Some comments about point 5 (objects running simultaneously in VEE 4.00)
and 1 question about Vee 4.0 :
I've not yet tried Vee 4.00, but what I can tell some about Vee 3.21 and
multithreads.
In Vee 3.21, if you have several threads running simultaneously, and each
calling the same user function at the same time, these function calls will be
executed sequentially, on call after this other. And I hope it's unchanged in
Vee 4.00.
IS IT STILL TRUE IN VEE 4.0???
Note it's very usefull for "real time" features : if this function (and
others ...)
reads / writes a data, you could imagine the mess if all the function calls
try to read /write the same data in the "same time" ...
Hope this will help.
P-E Dereux
E S Lab
Bell Helicopter Textron Canada
multithreads.
Vee 4.00.
others ...)
P-E Dereux
E S Lab
