send q VRf-RunOnly_Maximize ww vrf dougk
website: ftp://fcext3.external.hp.com/dist/mxd/index.html
to: Vrf-Warren Pickles
cc: DK
date: Thursday, 21 August 1997 1427 MDT
> Date: Thu, 21 Aug 97 10:24:24 -0500
> From: "Warren Pickles"<picklesw@amp.com>
> Hello all,
> Thanks to John and Bruce for their informative responses.
> Unfortunately none of the suggestions worked!
> If I do not set the geometry option, each time I run VEE RunOnly, the
> window comes up "cascaded" relative to the window position of the last
> application to be started. That is, the new window will be
> approximately the width of a title bar down, and the same distance to
> the right of, the previous window position.
> If I set the geometry option, either in the command line or in the
> v.ini file, it has no effect on size or position other than it makes
> them constant: the top left corner of the window is roughly in the
> centre of the screen, and the window size is as it was when the file
> was saved.
> Any ideas?
> Thanks,
> Warren
Sir:
I have been lobbying for a Maximize option on RunOnly but it isn't here yet.
We've been getting a number of complaints about this problem so I hope we can
resolve it in a future version.
[<>] regards -- gvg
cc: DK
> Hello all,
> was saved.
> Any ideas?
> Thanks,
> Warren
Sir:
[<>] regards -- gvg
