Is it possible to IO on the parallel port. The serial port can be addressed via HP SICL, but this does not work for the printer port.
ALBERT HEBERLE
Best regards,
ALBERT HEBERLE
Dr. Albert P. Heberle
HITACHI Cambridge Laboratory
Cavendish Laboratory
Madingley Road
Cambridge CB3 OHE
United Kingdom
Tel: +44 - 1223 467944
Fax: +44 - 1223 467942
Email: heberle@phy.cam.ac.uk
ALBERT HEBERLE
Best regards,
ALBERT HEBERLE
Madingley Road
Cambridge CB3 OHE
United Kingdom
> Is it possible to IO on the parallel port. The serial port can be =
> ALBERT HEBERLE
> Best regards,
> ALBERT HEBERLE
> Madingley Road
> Cambridge CB3 OHE
> United Kingdom
Sir:
You would have to use the PEEKPOKE CSUB to do this job. The following
document gives some details on parallel port registers. This might be
difficult or impossible under NT, however, since it restricts I/O access.
If you have more questions, let us know.
Wile E. Coyote at Acme Electronics Corporation
Reality is what refuses to go away when I stop believing in it.
Greg Goebel NET: gvg@lvld.hp.com
Hewlett-Packard / MXD Marketing PHONE: Telnet/970 679-3424
POB 301 / MS-CU326 / Loveland CO 80539 FAX: Telnet/970 679-5971
