As several people pointed out, removing the Start object and pressing run will enable time-slicing to work.
However, if there is 1 start object anywhere in a thread time-slicing does not work at any level below it
(neither user objects or functions). It is possible to remove all start objects, however it would be a lot of
work as no feedback would be possible. Also with no start objects debugging would be much more difficult as
there would be no way to start executing at a lower level.
Name: Tom Sanders, Symtx (formerly Symmetrix)
Date: 05/08/97 Time: 11:23:10
