Displaying formatted real numbers
Question asked by VRFuser on Jul 25, 1997
On Fri, 25 Jul 1997, Laurent PERDEREAU wrote:
> Hi,
> I am using HP VEE 4.01 under WIN 95. I use in a program a drop down list
> to select real values. This values depend on a previous value. So they are
> calculated just before the execution of the drop down list, and are sent in
> the enum values input pin. The result is that it displays in the drop down
> list
> the values with more than ten significant digit. I would like to known how
> i can do to have this in my drop down list:
>      0.2u
>      10.1M
> instead of :
>      0.00000021256
>      10100002.0256
> thanks a lot.
I think you can do it by using a formula object just before giving the
input to the drop-down list. The formula( or a set of formulae)  should
convert the the real values to your desired format.
Hope this helps you.
mir
Mir Mahiuddin,
Hughes Software Systems,
Tel - +91-124-343703 ext 2274
Email : mmahiuddin@hss.hns.com
        mahiuddin@pemail.net
