VRf-List_Values
Question asked by VRFuser on Jul 26, 1997
send q VRf-List_Values ww vrf perdero@cnrs-orleans.fr
      website:  ftp://fcext3.external.hp.com/dist/mxd/index.html
to:   VRf-Laurent Perdereau
date: Sunday, 27 July 1997 1133 MDT
> To: hpvxd_xc%hpislsup.lvld.hp.com@hplb.hpl.hp.com
> From: Laurent PERDEREAU <perdero@cnrs-orleans.fr>
> Subject: Vrf:Displaying formatted real numbers
> Hi,
> I am using HP VEE 4.01 under WIN 95. I use in a program a drop down list
> to select real values. This values depend on a previous value. So they are
> calculated just before the execution of the drop down list, and are sent in
> the enum values input pin. The result is that it displays in the drop down
> list
> the values with more than ten significant digit. I would like to known how
> i can do to have this in my drop down list:
>      0.2u
>      10.1M
> instead of :
>      0.00000021256
>      10100002.0256
> thanks a lot.
Sir:
I suggest you run the values through a To String before loading them into
the List object.  You will need to have a separate transaction in the To
String to format each array element in a Scientific format:
   WRITE TEXT a[0] REAL SCI:2 EOL
   WRITE TEXT a[1] REAL SCI:2 EOL
If you have more questions, let us know.
[<>] regards -- gvg
