VRf-E1413_Etc
Question asked by VRFuser on May 19, 1997
send q VRf-E1413_Etc ww Rene_Debets@msn.com vrf
to:   Rene Debets
date: Monday, 19 May 1997 1633 MDT
> I have tried the VEE driver for the E1413B/C with the E1413A card but
> I'm getting strange behaviour/results. Unless I have a bad card I suspect
> that the B/C
> version driver doesn't cover the A version. Is this correct? Is there a
> driver available for the E1413A?
It's not the VEE driver ... ISCPI on Win95 doesn't understand the E1413A.
You will need to update E1413A flash EPROM.  We need to know your current
version of flash EPROM -- you can obtain this with the commands:
   *IDN?
   DIAG:VERS?
> I'm also planning on moving from an external PC + HPIB to the RADE7PC
> for the VXI frame. Questions:
> Will VEE (together with Win95) run on this platform?
> Will it increase processing speed substantialy?
Yes, and yes.
> Best regards, Rene Debets
Please stay in touch.
[<>] regards -- gvg
