send q VRf-Export_Test_Results ww vrf lironno@rafael.co.il
website: ftp://fcext3.external.hp.com/dist/mxd/index.html
to: VRf-Noli Liron
date: Wednesday, 30 July 1997 1110 MDT
> Date: Sun, 27 Jul 1997 23:47:36 +0300
> From: Noli Liron <lironno@rafael.co.il>
> Organization: RAFAEL
> To: HP-VEE USER GROUP <hpvxd_xc@hpislsup.lvld.hp.com>
> Subject: Problems With Exporting Test Results?
Sir:
If you are referring to a To File object, then have you changed the output
format from DEFAULT FORMAT to REAL:FIX 2 or some other format? If you use
DEFAULT FORMAT then you will get full precision (and the usual obnoxious
floating-point far-right inaccuracies.
If there is something else of concern here, please let me know.
[%%] regards -- gvg
--------------------------------- cut here ----------------------------------
> Hello There,
> VEE 4.01 is my main tool to write test programs and control instruments.
> I use MS Access or Excel as my test database and report generator.
> One can use few ways to transfer the test results from VEE to the other
> applications. Usually I use DDE to transfer data to Excel.
> For Access, I write data to a delimited text file, later on the text
> file data is imported to Access by a data-import-macro.
> Manipulating numbers in VEE creates probelms:
> Multiply 1 * 0.1, you get an obvious 0.1. but if you write the results
> to a text file, you notice that it is 0.10000000000000001. If you change
> the
> "Alphanumeric" object number format to 18 digits, you see it!
> Have you noticed that? Does it make your hair turn white? Do you have a
> solution?
> If yey, please let me know,
> If ney, Look at the attached file RoundEng.zip. Unpack the file, and in
> RoundEng.vee you can see how to round numbers and export test results as
> text strings.
> Donations and Contributions to (Just kidding)
> Noli Liron,
> 9 Harakafot Street, Haifa 34745 Israel
> Home Tel: 972-4-838-9741, 972-4-838-1394
> Work Tel: 972-4-879-2112, 972-4-879-5023, Work Fax: 972-4-879-2746
> Email: lironno@rafael.co.il
to: VRf-Noli Liron
Sir:
[%%] regards -- gvg
> Hello There,
> the
> solution?
> text strings.
> Noli Liron,
