send q Re:_Need_JCT ww vrf mgustin@smsmfg.sms.siemens.com
website: ftp://fcext3.external.hp.com/dist/mxd/index.html
to: VRf-Mike Gustin
date: Friday, 08 August 1997 0920 MDT
> From: "Gustin, Mike" <mgustin@smsmfg.sms.siemens.com>
> To: HP VEE <hpvxd_xc@hpislsup.lvld.hp.com>
> Subject: Vrf: Need JCT in Feedback Loop Problem
> Date: Thu, 07 Aug 97 17:47:00 EDT
> Hi, any help or suggestions for this problem will be appreciated.
> I am trying to convert a program that ran on HP Vee version 3.12 with no
> problems to HP-Vee version 4.0.
> I am getting Error 935, which says that I need a JCT in a feedback loop. The
> problem is that there is no feedback loops and it says that an Import Object
> is the causing the problem. Since an Import Object has no output I am
> confused.
> Any suggestions?
> Mike Gustin
> mgustin@smsmfg.sme.siemens.com
Sir:
Do you have any reasonable sample code we can inspect to investigate this
problem?
[<>] regards -- gvg
to: VRf-Mike Gustin
> confused.
> Any suggestions?
> Mike Gustin
Sir:
problem?
[<>] regards -- gvg
