I try to program the IEC-Bus (HP-IB).
There is no Problem, if the HP-VEE-Computer will be the "system controler".
If I disable the "system controler", I have no access to the HB-IB.
Is it possible to access the HP-IB by a HP-VEE proram if the "system controller"
is disabled in HP Interface Configuration Application - I/O-Config ?
Are there any utilities that support HP-IB programming in HP-VEE to solve this
problem. Does anybody knows how its possible to program a communication
between two HP-VEE computers by using the HP-IB ?
Any suggestions?
Many thanks.
Any suggestions?
Many thanks.
