We have come up with a "work around" for this problem.
We added an extra direct I/O object in front of the first
legitimate direct I/O object for the serial port. This
dummy just does an execute reset and has an ERROR
pin which is not tied to anything. It apparently bit
buckets the error then SICL seems OK after that.
There is still some SICL problem underneath but it
only seems to impact the first call.
Regards
......Rob
From: SERGEY_ERMOLIN[SMTP:SERGEY_ERMOLIN@HP-SantaClara-om2.om.hp.com]
Sent: Monday, May 19, 1997 10:52 AM
To: ramarquardt
Cc: hpvxd_xc
Subject: Re: VRf: SICL internal error
Item Subject: VRf: SICL internal error
I second that - have the same error message on EVERY RESTART of my
program. Running VEE 4.0 under Windows NT 4.0 96mb RAM, HPIB is
82341D.
Sergey Ermolin
______________________________ Reply Separator
_________________________________
Author: Non-HP-ramarquardt (ramarquardt@mke5.ra.rockwell.com) at
HP-SantaClara,shargw1
Date: 5/19/97 8:12 AM
Running VEE 3.21 under Windows NT 4.0
16mb RAM, HPIB is 82341C
After a power cycle we get an internal SICL error
when sending an "EXECUTE RESET" to serial port COM4.
Error 999
Internal Error: SICL call made with bad parameter
Any ideas will be greatly appreciated.
Thanks
Rob Marquardt
System Test Engineering
Rockwell Automation / Allen-Bradley
Milwaukee, Wisconsin, USA
Regards
......Rob
To: ramarquardt
Cc: hpvxd_xc
82341D.
Sergey Ermolin
Error 999
Thanks
Rob Marquardt
