send q VRf-Driver_Problems ww vrf mgustin@smsmfg.sms.siemens.com
to: VRf-Mike Gustin
date: Sunday, 30 March 1997 1116 MST
Sir:
I tried this myself with the 894xx ID on 3.21 on Win3.1 ... no problem found.
I think something is seriously wrong ... please do a SCANDISK on your hard
drive and also check to see if you have any viruses.
> Hi,
> I am using the 89441 vee driver and I am running into problems. As soon as I
> try to add a terminal to the input I get an application error and I get
> knock out of HP-Vee. The problem only occurs when I use a input terminal
> that is above R in the alphabetically listing of possible input terminals.
> The error message occurs immediately upon clicking a terminal to add.
> I am using HP-Vee 3.12 on windows 3.11.
> The following things have been tried but with no success
> - I have downloaded the lastest driver.
> - Reinstalled HP-Vee
> - I have run ckitpro on the hardware looking for memory problems.
> - I have installed qemm to maximize the amount of memory available.
> I have another PC system with HP-Vee and the problem does not occur. The
> two systems autoconfig.bat and config.sys are almost identical.
> I would appreciate any suggestions on how to fix this problem
> Mike Gustin
> mgustin@sme.siemens.com
Please stay in touch.
[<>] regards -- gvg
to: VRf-Mike Gustin
Sir:
> Hi,
> Mike Gustin
[<>] regards -- gvg
