Ted's vee program is the right answer, but to give you a little more info,
the first bytes of dig_io.du are "DIAG:DRIV:LOAD #800067481" which tells
us that you can just do a WRITE BINARY of the file itself.
Mark Ahrens mark_ahrens@hp.com
Hewlett Packard FAX: 303-754-4802
US TMO Call Center
Englewood, CO
"Ask me about working for HP"
>Help,
>We have a 1406A which needs a new driver loaded.
>Does anyone have a VEE program for doing this?
>The file we are trying to load is: dig_io.du [from HP website] [size
>67481]
>So far I have allocated driver RAM space using
>DIAG:DRAM:CRE 140000,1 - for 1 driver
>Rebooted using
>DIAG:BOOT
>Checked the Ram allocation using
>DIAG:DRAM:CRE? - returns +140000,+1
>Tried various formats of
>DIAG:DRIV:LOAD #0<data> - get multiple errors, bad separator, invalid
>block data, etc
>DIAG:DRIV:LOAD #567481<data><EOL> - get +1301,Bad Driver Format
>Any suggestions or answers would be greatly appreciated
>Thanks in advance
>Rob Marquardt
>System Test Engineering
>Rockwell Automation / Allen-Bradley
>Milwaukee, Wisconsin, USA
67481]
Rebooted using
DIAG:BOOT
block data, etc
Thanks in advance
Rob Marquardt
