send q VRf-F_Keys ww mike.groves@ericsson.com vrf
to: VRf-Mike Groves
date: Friday, 23 May 1997 1553 MDT
Sir:
On the function keys: The lab says that's the way it works -- if you have
two OK buttons assigned to the same function key, if both are enabled, they
both fire.
If you have more questions, let us know.
[%%] regards -- gvg
--------------------------------- cut here ----------------------------------
> =46rom: mike.groves@ericsson.com
> To: Vee Reflector
> Subject: Problems with using F-Keys with OK buttons
> Platform: HP Vectra Pentium, VEE 4.0
> Ok guys, I see you've worked a little on the OK with Function Key
> problems, but they ain't fixed entirely yet.
> Here's a problem described using VEE 4.0 (3.x and 2.x act similar):
> In the simple program below, I have in the Main Box 5 OK buttons
> assigned to the function keys F1-F5. F1 and F2 don't do anything
> except loop back. F3 starts UserObject "Sub-1" executing. F4 will
> generate a User Error and F5 stops the loop, and the program.
> In the UserObject Sub-1, I have 4 more OK buttons assigned to F2-F5.
> =462 and F4 should do nothing except loop back. F3 breaks the loop
> and exits. F5 executes an "Exit UserObject" command.
> Arrange the Main and Sub-1 boxes so you can see them both on the
> screen at the same time. Start the program running. USING A
> MOUSE, hit the F1 and F2 buttons in the Main box. Now click on the
> =463 button. Move your mouse to the Sub-1 box and click on F2 and
> =464 a while. Now try F3 or F5 to get back to the Main box.
> So what's the problem, you ask? Go back and try the exact same
> thing only NOW using the keyboard. If your computer acts like mine,
> by pressing a single function key while in Sub-1, you execute
> BOTH the Main and Sub-1 threads for that function key, and the
> Sub-1 thread is terminated. If you press F1 while in Sub-1, the
> thread in Sub-1 is terminated and you are returned to Main.
> This can be a real problem if say in your Main program you assigned
> =461 to activate a HELP routine and sometime later, deep in a nested
> subroutine or function, someone hits the F1 key and ends up
> back on the Main thread, never to return to what he was doing.
> The other problem it poses is never being able to assign the
> =46unction Keys to more than one task. If the user presses the key
> instead of clicking on it with a mouse, who knows how many "old"
> =46-Key assignments will spring into action at the same time.
> Thanks for listening to me rant,
> Mike Groves
> Program:
> (saveFormat "2.3")
> (date "Mon 19/May/1997 19:31:16 ")
> (veerev "4.0")
> (platform "PC")
> (execMode fast)
> (filterNAN 0)
> (workspaceStackingOrder M M.33)
> (SaveCF no)
> (device 0 ROOTCONTEXT
> (properties
> (trigMode deg)
> (nextID 42)
> (popupTitleText "Untitled")
> (popupMoveable 1)
> (deleteGlobals 0))
> (deviceList
> (device 5 REPEATUNTILBREAK
> (interface
> (output 1
> (name "Continuous")
> (lock name constraints))))
> (device 6 CONFIRM25
> (properties
> (name "F1: OK ")
> (enterButton 0)
> (escapeButton 0)
> (isAssigned2FKey F1))
> (interface
> (output 1
> (name "Go")
> (implementation))
> (device 15 CONFIRM25
> (properties
> (name "F2: OK ")
> (enterButton 0)
> (escapeButton 0)
> (isAssigned2FKey F2))
> (interface
> (output 1
> (name "Go")
> (implementation))
> (device 22 LITERALCONSTANT
> (properties
> (name ""F1""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F1"))
> (initValue Text
> (data ""))))
> (device 23 LITERALCONSTANT
> (properties
> (name ""F2""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F2"))
> (initValue Text
> (data ""))))
> (device 25 START25)
> (device 26 NEXT)
> (device 27 NEXT)
> (device 29 TEXTDISPLAY
> (interface
> (input 1
> (name "Data"))))
> (device 30 JUNCTION
> (properties
> (name "JCT"))
> (interface
> (input 1
> (name "A")
> (input 2
> (name "B")
> (input 3
> (name "C")
> (optional yes))
> (input 4
> (name "D")
> (optional yes))
> (input 5
> (name "E")
> (optional yes))
> (output 1
> (name "Data"))))
> (device 31 CONFIRM25
> (properties
> (name "F4: OK ")
> (enterButton 0)
> (escapeButton 0)
> (isAssigned2FKey F4))
> (interface
> (output 1
> (name "Go")
> (implementation))
> (device 32 ESCAPE
> (properties
> (errorCode 666)
> (message "F4 in Main was tripped!")))
> (device 33 CONTEXT
> (properties
> (name "Sub-1")
> (trigMode deg)
> (nextID 40)
> (popupTitleText "UserObject")
> (popupMoveable 1))
> (deviceList
> (device 15 TEXTDISPLAY
> (interface
> (input 1
> (name "Data"))))
> (device 16 JUNCTION
> (properties
> (name "JCT"))
> (interface
> (input 1
> (name "A")
> (input 2
> (name "B")
> (input 3
> (name "C")
> (optional yes))
> (input 4
> (name "D")
> (optional yes))
> (output 1
> (name "Data"))))
> (device 18 LITERALCONSTANT
> (properties
> (name ""F5""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F5"))
> (initValue Text
> (data ""))))
> (device 19 CONFIRM25
> (properties
> (name "F5: OK ")
> (enterButton 0)
> (escapeButton 0)
> (isAssigned2FKey F5))
> (interface
> (output 1
> (name "Go")
> (implementation))
> (device 21 LITERALCONSTANT
> (properties
> (name ""F4""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F4"))
> (initValue Text
> (data ""))))
> (device 22 CONFIRM25
> (properties
> (name "F4: OK ")
> (enterButton 0)
> (escapeButton 0)
> (interface
> (output 1
> (name "Go")
> (implementation))
> (device 25 LITERALCONSTANT
> (properties
> (name ""F3""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F3"))
> (initValue Text
> (data ""))))
> (device 26 CONFIRM25
> (properties
> (name "F3: OK ")
> (enterButton 0)
> (escapeButton 0)
> (isAssigned2FKey F3))
> (interface
> (output 1
> (name "Go")
> (implementation))
> (device 27 NEXT)
> (device 28 LITERALCONSTANT
> (properties
> (name ""F2""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F2"))
> (initValue Text
> (data ""))))
> (device 29 CONFIRM25
> (properties
> (name "F2: OK ")
> (enterButton 0)
> (escapeButton 0)
> (interface
> (output 1
> (name "Go")
> (implementation))
> (device 34 REPEATUNTILBREAK
> (interface
> (output 1
> (name "Continuous")
> (device 35 BREAK)
> (device 36 EXITCONTEXT
> (properties
> (name "Exit")))
> (device 39 NEXT)
> (configuration
> (connect D1:1 D0:1)
> (connect D2:1 D1:1)
> (connect D4:1 D1:2)
> (connect D6:1 D1:3)
> (connect D9:1 D1:4)
> (connect D3:0 D2:0)
> (connect D11:1 D3:0)
> (connect D5:0 D4:0)
> (connect D11:1 D5:0)
> (connect D7:0 D6:0)
> (connect D11:1 D7:0)
> (connect D9:0 D8:0)
> (connect D10:0 D9:0)
> (connect D11:1 D10:0)
> (connect D6:0 D12:0)
> (connect D2:0 D13:0)
> (connect D4:0 D14:0)))
> (contextCarrier
> (wndOrigin 5 313)
> (wndState res)
> (active detail)
> (detail
> (extent 752 311)
> (anchorPt -31 -112)
> (configuration
> (devCarrierFor 15
> (active open)
> (icon)
> (open
> (extent 122 29))
> (pinCenter 700 330))
> (devCarrierFor 16
> (active icon)
> (icon
> (extent 29 54))
> (open)
> (terminals on)
> (pinCenter 610 330))
> (devCarrierFor 18
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (pinCenter 530 260))
> (devCarrierFor 19
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (pinCenter 530 230))
> (devCarrierFor 21
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (pinCenter 420 260))
> (devCarrierFor 22
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (pinCenter 420 230))
> (devCarrierFor 25
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (pinCenter 320 260))
> (devCarrierFor 26
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (pinCenter 320 230))
> (devCarrierFor 27
> (active icon)
> (icon
> (extent 31 16))
> (open)
> (terminals on)
> (pinCenter 220 290))
> (devCarrierFor 28
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (pinCenter 220 260))
> (devCarrierFor 29
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (pinCenter 220 230))
> (devCarrierFor 34
> (active icon)
> (icon
> (extent 74 52)
> (iconImage "loop.icn"))
> (open)
> (terminals on)
> (pinCenter 90 200))
> (devCarrierFor 35
> (active icon)
> (icon
> (extent 41 16))
> (open)
> (terminals on)
> (pinCenter 320 290))
> (devCarrierFor 36
> (active icon)
> (icon
> (extent 26 16))
> (open)
> (terminals on)
> (pinCenter 530 290))
> (devCarrierFor 39
> (active icon)
> (icon
> (extent 31 16))
> (open)
> (terminals on)
> (pinCenter 420 290))
> (connect D1:1 D0:1
> (points 2 627 330 636 330))
> (connect D2:1 D1:1
> (points 4 548 260 570 260 570 310 593 310))
> (connect D4:1 D1:2
> (points 4 438 260 480 260 480 320 593 320))
> (connect D6:1 D1:3
> (points 4 338 260 360 260 360 330 593 330))
> (connect D9:1 D1:4
> (points 4 238 260 260 260 260 340 593 340))
> (connect D3:0 D2:0
> (points 2 530 244 530 249))
> (connect D11:1 D3:0
> (points 3 129 200 530 200 530 216))
> (connect D5:0 D4:0
> (points 2 420 244 420 249))
> (connect D11:1 D5:0
> (points 3 129 200 420 200 420 216))
> (connect D7:0 D6:0
> (points 2 320 244 320 249))
> (connect D11:1 D7:0
> (points 3 129 200 320 200 320 216))
> (connect D9:0 D8:0
> (points 2 220 270 220 279))
> (connect D10:0 D9:0
> (points 2 220 244 220 249))
> (points 3 129 200 220 200 220 216))
> (connect D6:0 D12:0
> (points 2 320 270 320 279))
> (connect D2:0 D13:0
> (points 2 530 270 530 279))
> (connect D4:0 D14:0
> (points 2 420 270 420 279)))
> (stackingOrder 0 2 4 5 6 7 9 10 13 12 3 8 14 1 11))))
> (device 35 CONFIRM25
> (properties
> (name "F3: OK ")
> (enterButton 0)
> (escapeButton 0)
> (interface
> (output 1
> (name "Go")
> (implementation))
> (device 36 NEXT)
> (device 37 LITERALCONSTANT
> (properties
> (name ""F3""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F3"))
> (initValue Text
> (data ""))))
> (device 38 LITERALCONSTANT
> (properties
> (name ""F4""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F4"))
> (initValue Text
> (data ""))))
> (device 39 CONFIRM25
> (properties
> (name "F5: OK ")
> (enterButton 0)
> (escapeButton 0)
> (interface
> (output 1
> (name "Go")
> (implementation))
> (device 40 LITERALCONSTANT
> (properties
> (name ""F5""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F5"))
> (initValue Text
> (data ""))))
> (device 41 BREAK)
> (configuration
> (connect D5:0 D0:0)
> (connect D0:1 D1:0)
> (connect D0:1 D2:0)
> (connect D1:0 D3:0)
> (connect D2:0 D4:0)
> (connect D3:0 D6:0)
> (connect D4:0 D7:0)
> (connect D9:1 D8:1)
> (connect D18:1 D9:1)
> (connect D16:1 D9:2)
> (connect D15:1 D9:3)
> (connect D4:1 D9:4)
> (connect D3:1 D9:5)
> (connect D0:1 D10:0)
> (connect D16:0 D11:0)
> (connect D15:0 D12:0)
> (connect D0:1 D13:0)
> (connect D12:0 D14:0)
> (connect D13:0 D15:0)
> (connect D10:0 D16:0)
> (connect D0:1 D17:0)
> (connect D17:0 D18:0)
> (connect D18:0 D19:0)))
> (contextCarrier
> (wndOrigin 4 3)
> (wndState res)
> (active detail)
> (detail
> (extent 810 279)
> (anchorPt 45 61)
> (configuration
> (devCarrierFor 5
> (active icon)
> (icon
> (extent 74 52)
> (open)
> (terminals on)
> (pinCenter 20 20))
> (devCarrierFor 6
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (pinCenter 100 50))
> (devCarrierFor 15
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (pinCenter 200 50))
> (devCarrierFor 22
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 194 30))
> (pinCenter 100 80))
> (devCarrierFor 23
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (pinCenter 200 80))
> (devCarrierFor 25
> (active open)
> (icon)
> (open
> (extent 52 23))
> (title off)
> (pinCenter 20 -30))
> (devCarrierFor 26
> (active icon)
> (icon
> (extent 31 16))
> (open)
> (terminals on)
> (pinCenter 100 110))
> (devCarrierFor 27
> (active icon)
> (icon
> (extent 31 16))
> (open)
> (terminals on)
> (pinCenter 200 110))
> (devCarrierFor 29
> (active open)
> (icon)
> (open
> (extent 122 29))
> (pinCenter 680 150))
> (devCarrierFor 30
> (active icon)
> (icon
> (extent 29 54))
> (open)
> (terminals on)
> (pinCenter 590 150))
> (devCarrierFor 31
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (pinCenter 400 50))
> (devCarrierFor 32
> (active icon)
> (icon
> (extent 79 16))
> (open
> (extent 238 57))
> (pinCenter 400 110))
> (devCarrierFor 33
> (active icon)
> (icon
> (extent 42 16))
> (pinCenter 300 110))
> (devCarrierFor 35
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (pinCenter 300 50))
> (devCarrierFor 36
> (active icon)
> (icon
> (extent 31 16))
> (open)
> (terminals on)
> (pinCenter 300 140))
> (devCarrierFor 37
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (pinCenter 300 80))
> (devCarrierFor 38
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (pinCenter 400 80))
> (devCarrierFor 39
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (pinCenter 510 50))
> (devCarrierFor 40
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (pinCenter 510 80))
> (devCarrierFor 41
> (active icon)
> (icon
> (extent 41 16))
> (open)
> (terminals on)
> (pinCenter 510 110))
> (connect D5:0 D0:0
> (points 2 20 -16 20 -9))
> (connect D0:1 D1:0
> (points 3 59 20 100 20 100 36))
> (connect D0:1 D2:0
> (points 3 59 20 200 20 200 36))
> (connect D1:0 D3:0
> (points 2 100 64 100 69))
> (connect D2:0 D4:0
> (points 2 200 64 200 69))
> (connect D3:0 D6:0
> (points 2 100 90 100 99))
> (connect D4:0 D7:0
> (points 2 200 90 200 99))
> (connect D9:1 D8:1
> (points 2 607 150 616 150))
> (connect D18:1 D9:1
> (points 4 528 80 550 80 550 130 573 130))
> (connect D16:1 D9:2
> (points 4 418 80 460 80 460 140 573 140))
> (connect D15:1 D9:3
> (points 4 318 80 340 80 340 150 573 150))
> (connect D4:1 D9:4
> (points 4 218 80 240 80 240 160 573 160))
> (connect D3:1 D9:5
> (points 4 118 80 140 80 140 170 573 170))
> (connect D0:1 D10:0
> (points 3 59 20 400 20 400 36))
> (points 2 400 90 400 99))
> (points 2 300 90 300 99))
> (connect D0:1 D13:0
> (points 3 59 20 300 20 300 36))
> (points 2 300 120 300 129))
> (points 2 300 64 300 69))
> (points 2 400 64 400 69))
> (connect D0:1 D17:0
> (points 3 59 20 510 20 510 36))
> (points 2 510 64 510 69))
> (points 2 510 90 510 99)))
> (stackingOrder 1 2 13 10 12 14 4 7 3 6 16 17 19 9 8 18 0 11 15 5))
> (numberFormats
> (realFormat standard)
> (realSigDigits 4)
> (realRadixSpec 4)
> (integerBase decimal))))
to: VRf-Mike Groves
Sir:
both fire.
[%%] regards -- gvg
> To: Vee Reflector
> Mike Groves
> Program:
> (saveFormat "2.3")
> (veerev "4.0")
> (platform "PC")
> (execMode fast)
> (filterNAN 0)
> (SaveCF no)
> (properties
> (trigMode deg)
> (nextID 42)
> (popupMoveable 1)
> (deleteGlobals 0))
> (deviceList
> (interface
> (output 1
> (name "Continuous")
> (device 6 CONFIRM25
> (properties
> (name "F1: OK ")
> (enterButton 0)
> (escapeButton 0)
> (interface
> (output 1
> (name "Go")
> (implementation))
> (properties
> (name "F2: OK ")
> (enterButton 0)
> (escapeButton 0)
> (interface
> (output 1
> (name "Go")
> (implementation))
> (properties
> (name ""F1""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F1"))
> (initValue Text
> (data ""))))
> (properties
> (name ""F2""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F2"))
> (initValue Text
> (data ""))))
> (device 25 START25)
> (device 26 NEXT)
> (device 27 NEXT)
> (interface
> (input 1
> (name "Data"))))
> (device 30 JUNCTION
> (properties
> (name "JCT"))
> (interface
> (input 1
> (name "A")
> (input 2
> (name "B")
> (input 3
> (name "C")
> (optional yes))
> (input 4
> (name "D")
> (optional yes))
> (input 5
> (name "E")
> (optional yes))
> (output 1
> (name "Data"))))
> (properties
> (name "F4: OK ")
> (enterButton 0)
> (escapeButton 0)
> (interface
> (output 1
> (name "Go")
> (implementation))
> (device 32 ESCAPE
> (properties
> (errorCode 666)
> (device 33 CONTEXT
> (properties
> (name "Sub-1")
> (trigMode deg)
> (nextID 40)
> (popupMoveable 1))
> (deviceList
> (interface
> (input 1
> (name "Data"))))
> (device 16 JUNCTION
> (properties
> (name "JCT"))
> (interface
> (input 1
> (name "A")
> (input 2
> (name "B")
> (input 3
> (name "C")
> (optional yes))
> (input 4
> (name "D")
> (optional yes))
> (output 1
> (name "Data"))))
> (properties
> (name ""F5""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F5"))
> (initValue Text
> (data ""))))
> (properties
> (name "F5: OK ")
> (enterButton 0)
> (escapeButton 0)
> (interface
> (output 1
> (name "Go")
> (implementation))
> (properties
> (name ""F4""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F4"))
> (initValue Text
> (data ""))))
> (properties
> (name "F4: OK ")
> (enterButton 0)
> (escapeButton 0)
> (interface
> (output 1
> (name "Go")
> (implementation))
> (properties
> (name ""F3""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F3"))
> (initValue Text
> (data ""))))
> (properties
> (name "F3: OK ")
> (enterButton 0)
> (escapeButton 0)
> (interface
> (output 1
> (name "Go")
> (implementation))
> (device 27 NEXT)
> (properties
> (name ""F2""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F2"))
> (initValue Text
> (data ""))))
> (properties
> (name "F2: OK ")
> (enterButton 0)
> (escapeButton 0)
> (interface
> (output 1
> (name "Go")
> (implementation))
> (interface
> (output 1
> (name "Continuous")
> (device 35 BREAK)
> (properties
> (name "Exit")))
> (device 39 NEXT)
> (configuration
> (connect D1:1 D0:1)
> (connect D2:1 D1:1)
> (connect D4:1 D1:2)
> (connect D6:1 D1:3)
> (connect D9:1 D1:4)
> (connect D3:0 D2:0)
> (connect D5:0 D4:0)
> (connect D7:0 D6:0)
> (connect D9:0 D8:0)
> (contextCarrier
> (wndOrigin 5 313)
> (wndState res)
> (active detail)
> (detail
> (extent 752 311)
> (anchorPt -31 -112)
> (configuration
> (devCarrierFor 15
> (active open)
> (icon)
> (open
> (extent 122 29))
> (devCarrierFor 16
> (active icon)
> (icon
> (extent 29 54))
> (open)
> (terminals on)
> (devCarrierFor 18
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (devCarrierFor 19
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (devCarrierFor 21
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (devCarrierFor 22
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (devCarrierFor 25
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (devCarrierFor 26
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (devCarrierFor 27
> (active icon)
> (icon
> (extent 31 16))
> (open)
> (terminals on)
> (devCarrierFor 28
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (devCarrierFor 29
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (devCarrierFor 34
> (active icon)
> (icon
> (extent 74 52)
> (open)
> (terminals on)
> (pinCenter 90 200))
> (devCarrierFor 35
> (active icon)
> (icon
> (extent 41 16))
> (open)
> (terminals on)
> (devCarrierFor 36
> (active icon)
> (icon
> (extent 26 16))
> (open)
> (terminals on)
> (devCarrierFor 39
> (active icon)
> (icon
> (extent 31 16))
> (open)
> (terminals on)
> (connect D1:1 D0:1
> (connect D2:1 D1:1
> (connect D4:1 D1:2
> (connect D6:1 D1:3
> (connect D9:1 D1:4
> (connect D3:0 D2:0
> (connect D11:1 D3:0
> (connect D5:0 D4:0
> (connect D11:1 D5:0
> (connect D7:0 D6:0
> (connect D11:1 D7:0
> (connect D9:0 D8:0
> (connect D10:0 D9:0
> (connect D6:0 D12:0
> (connect D2:0 D13:0
> (connect D4:0 D14:0
> (properties
> (name "F3: OK ")
> (enterButton 0)
> (escapeButton 0)
> (interface
> (output 1
> (name "Go")
> (implementation))
> (device 36 NEXT)
> (properties
> (name ""F3""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F3"))
> (initValue Text
> (data ""))))
> (properties
> (name ""F4""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F4"))
> (initValue Text
> (data ""))))
> (properties
> (name "F5: OK ")
> (enterButton 0)
> (escapeButton 0)
> (interface
> (output 1
> (name "Go")
> (implementation))
> (properties
> (name ""F5""))
> (interface
> (output 1
> (name "Text")
> (implementation
> (value Text
> (data "F5"))
> (initValue Text
> (data ""))))
> (device 41 BREAK)
> (configuration
> (connect D5:0 D0:0)
> (connect D0:1 D1:0)
> (connect D0:1 D2:0)
> (connect D1:0 D3:0)
> (connect D2:0 D4:0)
> (connect D3:0 D6:0)
> (connect D4:0 D7:0)
> (connect D9:1 D8:1)
> (connect D4:1 D9:4)
> (connect D3:1 D9:5)
> (contextCarrier
> (wndOrigin 4 3)
> (wndState res)
> (active detail)
> (detail
> (extent 810 279)
> (anchorPt 45 61)
> (configuration
> (devCarrierFor 5
> (active icon)
> (icon
> (extent 74 52)
> (open)
> (terminals on)
> (pinCenter 20 20))
> (devCarrierFor 6
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (pinCenter 100 50))
> (devCarrierFor 15
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (pinCenter 200 50))
> (devCarrierFor 22
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 194 30))
> (pinCenter 100 80))
> (devCarrierFor 23
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (pinCenter 200 80))
> (devCarrierFor 25
> (active open)
> (icon)
> (open
> (extent 52 23))
> (title off)
> (pinCenter 20 -30))
> (devCarrierFor 26
> (active icon)
> (icon
> (extent 31 16))
> (open)
> (terminals on)
> (devCarrierFor 27
> (active icon)
> (icon
> (extent 31 16))
> (open)
> (terminals on)
> (devCarrierFor 29
> (active open)
> (icon)
> (open
> (extent 122 29))
> (devCarrierFor 30
> (active icon)
> (icon
> (extent 29 54))
> (open)
> (terminals on)
> (devCarrierFor 31
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (pinCenter 400 50))
> (devCarrierFor 32
> (active icon)
> (icon
> (extent 79 16))
> (open
> (extent 238 57))
> (devCarrierFor 33
> (active icon)
> (icon
> (extent 42 16))
> (devCarrierFor 35
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (pinCenter 300 50))
> (devCarrierFor 36
> (active icon)
> (icon
> (extent 31 16))
> (open)
> (terminals on)
> (devCarrierFor 37
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (pinCenter 300 80))
> (devCarrierFor 38
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (pinCenter 400 80))
> (devCarrierFor 39
> (active open)
> (icon
> (extent 53 0))
> (open
> (extent 52 23))
> (title off)
> (pinCenter 510 50))
> (devCarrierFor 40
> (active icon)
> (icon
> (extent 31 16))
> (open
> (extent 77 32))
> (pinCenter 510 80))
> (devCarrierFor 41
> (active icon)
> (icon
> (extent 41 16))
> (open)
> (terminals on)
> (connect D5:0 D0:0
> (connect D0:1 D1:0
> (connect D0:1 D2:0
> (connect D1:0 D3:0
> (connect D2:0 D4:0
> (connect D3:0 D6:0
> (connect D4:0 D7:0
> (connect D9:1 D8:1
> (connect D18:1 D9:1
> (connect D16:1 D9:2
> (connect D15:1 D9:3
> (connect D4:1 D9:4
> (connect D3:1 D9:5
> (connect D0:1 D10:0
> (connect D0:1 D13:0
> (connect D0:1 D17:0
> (numberFormats
> (realSigDigits 4)
> (realRadixSpec 4)
